20 Most Recent
Seiko Divers SKXA35 Wrist Watch Questions & Answers
Previously accurate Seiko dive watch suddenly gaining 1-2 hrs/day
if your watch caliber is 7s26b(look at the case back plate)is a usual problem of those calibers!the hair spring stuck somehow and the watch runs!a seiko authorized sevice center can help you!dont let anybody else magician to ruin your watch!is a routine repair for someone with knowledge and support from seiko!
Install Band
does it have those small pins that you can take off in order to take the bracelets off?
drcool
How can I turn off the alarm on my Seiko quartz alarm
TO CANCEL THE ALARM TIME YOU HAVE SET ;
1.Pull out the crown to the first click, and press and hold button “B” until the alarm hands stop to indicate the current time.
2. Push the crown back in to the normal position.
Reset time on a seiko solar watch
you should be able to set it with the stem if your having trouble it may have to go into seiko the solar watches can be very complicated
How do I reset the Seiko ch-899
You can follow these steps to reset your watch manually:
- Press and hold "SET" button for 2 seconds until the hour digit.
- Press "ADJUST" button to change the value of the hour digit.
- Press the "SET" button once, the minute digits will flash.
- Press the "SET" button once, the second digits will flash.
- Press the "SET" button, "12H" or "24H" will flash.
