20 Most Recent Microsoft Visual Studio 2008 Professional Full Version for PC Questions & Answers
Have first page of book Head First C# page 15 first exercise
went to their site forum, but it's bugged too, thats fuunny well if their well paid IT team cant sort it cant see why you have to try a telephone contact support number and grab a bite to eat ,,until they pick up your call
3/8/2017 12:10:14 PM • Microsoft Visual... • Answered on Mar 08, 2017
Free download microsoft visual studio
Search it from torrentz.com . U'll definitely find what u r looking for .
12/6/2011 7:10:22 PM • Microsoft Visual... • Answered on Dec 06, 2011
How can i downlod visual
You can download a 90 day trial directly from Microsoft.Visit: http://www.microsoft.com/download/en/details.aspx?id=3713 and click the download button.
7/20/2011 4:38:50 PM • Microsoft Visual... • Answered on Jul 20, 2011
How to convert vba macros to visual studio?
  1. Clean your code. There are built in Application specific functions which don't work in VB Studio. Some will require you pre-load the application first, others just don't work at all.
  2. Save the VBA module as a BAS file. This is just a text file with the module code in it.
  3. Export your forms to file.
  4. Open Visual Studio
  5. Import your forms and modules
  6. Clean it up.
  7. Compile it
4/28/2010 11:52:54 AM • Microsoft Visual... • Answered on Apr 28, 2010
2answers
I'm getting an error
instance failure appears wen u have created an object for a class that instantiated it during run time. that is check ur classes for which u created objects and see with which object u have accessed the action of login form.
12/15/2009 7:39:43 AM • Microsoft Visual... • Answered on Dec 15, 2009
2answers
What is a error C2563: mismatch in formal
ok, look at the following example
void Run(string* message, char& type)
in the program I put
Run("help");
this will result in the mismatch error as there are two parameters not one.
Regards
gewiz.co.uk
12/5/2009 4:52:24 PM • Microsoft Visual... • Answered on Dec 05, 2009
A simple program in which image changes in 5 sec
if it is in java i can do it
7/26/2009 7:32:01 AM • Microsoft Visual... • Answered on Jul 26, 2009
Visual basic 2008 change location of user.config
You can change the location by setting the Application.LocalUserAppDataPath property when the application starts.
Hope this helps. If you need further help, I’m available over the phone at https://www.6ya.com/expert/kenneth_305861ac5ab3ccfd
4/1/2009 8:40:32 PM • Microsoft Visual... • Answered on Apr 01, 2009
I am getting the C2664:Can't convert parameter 1 to LPCSTR
Parameter 1 is probably not a string. If fact based on the code snippet it looks like parameter 1 "sring1" maybe should be spelled "string1" If you need further help, I’m available over the phone at https://www.6ya.com/expert/kenneth_305861ac5ab3ccfd
4/1/2009 8:26:44 PM • Microsoft Visual... • Answered on Apr 01, 2009
2answers
Caller id not working
Jus Switch off the phone and Start it again. Then notify me about the changes in the phone.
2/26/2009 12:44:40 PM • Microsoft Visual... • Answered on Feb 26, 2009
5answers
Microsoft office Bootstrapper has stopped
tep1: - Firewall Disable The users should try to temporarily disable Firewall or other security programs on their system. Step2: - Uninstall Old version of Microsoft Office If the users have installed the old version of Microsoft Office, then they need to instant uninstall it. In any case, if the MS office does not uninstall by using the Control Panel, then they have to download Microsoft Fix Tool and then use it to remove the old version of office of their PC. Step3: -Install Microsoft Office in Clean Boot Boot the system in the clean boot and then try to install the Office 2013 program and check that the clean boot is performed to disable all startup programs and the third party services on the machine. Also, check if they are conflicting with the Office installation. Then restart the computer in Windows Clean Boot and then try to install Microsoft Office 2013 program. Step4: - Check the Services Is Running Properly The users need to ensure that the following services are running properly in the services console. Go to "Start" button and then go to "Run" command. In the command prompt, type "Services.msc" cmd and tap on "Enter" key.
  • Check the Print Spooler
  • Check the Task Scheduler & respective dependencies
Step5:- Check Internet Connection The users need to ensure that their Internet Connection to the system is properly working or not. Might require download few Microsoft utilities at distinct stages. Step6:- Repair OSE Service Follow these steps:
  • Go to Office "install disc" option, and then find ose.exe and osetup.dll.
  • Then need to create a folder for OSE: C:\Program Files\Common Files\microsoft shared\Source Engine
  • Now copy the "OSE.exe" file to that folder.
  • Then restart your machine.
  • Now try to install Office again.
3/7/2024 12:32:09 PM • Microsoft... • Answered on Mar 07, 2024
Product key for ms office 2010 -X16-32007
Not all office disks have the same codes, no matter the version you may need a whole new installation disk with the corresponding code
2/15/2024 4:22:18 PM • Microsoft... • Answered on Feb 15, 2024
My microsoft intergrated webcam works good on skpe. It will not open for me to video myself offline. can I download the same type without messing up my computer
all you need is a camera program or app that is compatible with your operating system and the computer hardware also check to see that your drivers are up to date
2/15/2024 4:21:26 PM • Microsoft... • Answered on Feb 15, 2024
I WANT THE CONFIRMATION CODE FOR MICROSOFT OFFICE PROFESSIONAL 2007 7 CHARACTERS A,B,C,D,E,F,G
2/15/2024 4:15:17 PM • Microsoft... • Answered on Feb 15, 2024
Microsoft Visual Studio 2008 Professional Full Version for PC  Logo
25 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Microsoft Computers & Internet
Most Popular Question
convert vba macros visual studio
  • Computers & Internet
