20 Most Recent
Evenflo ExerSaucer SmartSteps Active Learning Center Questions & Answers
Where are the batteries in evenflow ultra saucer
file:///C:/Users/erwooster/Downloads/25707060.pdf
States batteries are not replaceable, which means that they are buried somewhere inside the main module. Proceed at your own risk.
3/2/2015 10:13:03 PM •
Evenflo...
Answered
on Mar 02, 2015
How to reinstall seat for
DO A WEB SEARCH ENTERING NAME AND MODEL INSTRUCTIONS, YOU'LL FIND THEM OR ATLEAST FIND OUT THE MANUFACTURER INFO OF HOW TO CONTACT AND HAVE THEM EMAIL YOU THE INSTRUCTIONS.
I KNOW THEY ARE A PAIN TO ASSEMBLE ALONG WITH ALL CHILDRENS CAR SEATS ETC,.
HOPE THIS HELPS!
MARTIE
8/25/2011 8:35:59 PM •
Evenflo...
Answered
on Aug 25, 2011
Can't figure out how to
May I get the model # to help you more. To find it you need to look at one of thease areas. On the inside of one of the legs when you adjust it to the highest level, on the underside of the plastic seat ring, the underside of the tray, or on the bottom of the saucer.
2/13/2011 6:18:43 PM •
Evenflo...
Answered
on Feb 13, 2011
I need instructions for evenflo ultrasaucer model 25803867
See my clarification above. You NEED to remove this as a solution because it's NOT a solution! And where is my vote? nate99 now has 2 votes and it still only shows one. Obviously this is a bogus site put here to sell advertising. What a waste of time!
1/4/2011 7:41:54 PM •
Evenflo...
Answered
on Jan 04, 2011
I washed the seat cover
It has likely shrunk. Try wetting it and then stretching it on while it is wet. Let it dry while it is on.
1/3/2011 4:52:04 AM •
Evenflo...
Answered
on Jan 03, 2011
Whats the proper height when using the exersaucer
Place the product on level ground and make sure the legs are the same height. (The tray should be level.) That's the best way to avoid tip-overs.
Follow the manufacturer's age, weight, and height recommendations and keep the owner's manual for future reference. Don't use the activity center before your baby can sit up unassisted, and stop using it when your baby reaches the height or weight maximum and can walk or even stand up by himself, which means that he could easily tip it. And, as a general rule, if your child can tip over the activity center by just leaning over the edge or can climb out of it, it's time to retire it.
hope this helps.
8/4/2010 3:56:28 PM •
Evenflo...
Answered
on Aug 04, 2010
Instrucatins on putting together
You can download the instructions from Evenflo. Go to their support web site at
https://plweb.evenflo.com/replacement_parts.aspx and enter the model number of your unit. The site will show you a list of the available replacement parts, and in that list you should find an entry for the Instruction Manual. If you click there you will be able to save a PDF file of the instructions that you can read on your computer.
11/13/2009 10:03:22 PM •
Evenflo...
Answered
on Nov 13, 2009
