20 Most Recent
Evenflo Exersaucer Triple Fun Active Learning Center Questions & Answers
How do i convert it
hi here are the instructions
https://plweb.evenflo.com/product_search.aspx?txSearchModelNo=6231883&txSearchDOM=1/1/2010
3/20/2016 3:06:02 PM •
Evenflo...
Answered
on Mar 20, 2016
I am needing an instruction
hi
here is a page link to instruction download
near to bottom of the page
3/19/2016 12:51:35 PM •
Evenflo...
Answered
on Mar 19, 2016
I need assembly directions for evenflo exersaucer triple fun.
1. Remove toys and seat from the exersaucer.
2. Fold exersaucer, but do not let the tray lock to the base. With
exersaucer flat on the floor, twist each leg assembly (B) fully
clockwise until it stops. Fully depress one of the pedestal locking
tabs (C) then push on the leg assembly (B); leg will partially fold.
Repeat this for all four legs. After pressing the fourth pedestal
locking tab (C), the Exersaucer will fold with the tray (D) rotating
toward the base (E). Make sure all four tray locks. (F) are locked onto
the base before trying to carry exersaucer.
3. Place your fingers beneath the legs (A) push upward to disconnect
the leg assemblies from the pedestals (B). Repeat for all 4 leg
assemblies.
4. After all four legs have been disconnected from the pedestals, remove tray assembly (C) from the base (D).
5. Turn tray (C) upside down and remove both end caps (E) from beneath.
6. Squeeze both locking tabs (F) on each side of the tray to disconnect
and seperate the tray halves (C). 7. Connect tray halves (C) to form
activity table.
7. Connect tray halves (C) to form activity table.
8. Rotate leg assemblies (A) fully clockwise until they lock into
postition. Make sure all four legs lock (G) are locked properly into
the uper leg pedestal (H). Also make sure all four leg locks (I) are
sticking out past the edge of the tray.
9. Turn table over and install two end caps (E). Make sure both end
caps lock into place. NOTE: one end cap installs from above and the
other installs from below.
10. Install toys on activity table. If desired, adjust table to the
appropriate height for your child. IMPORTANT: NEVER use stage 3 without
end caps!
3/19/2016 12:49:41 PM •
Evenflo...
Answered
on Mar 19, 2016
How do I disasemble an Evenflo Ultrasaucer to
Here is a link to the manual: file:///C:/Users/erwooster/Downloads/25707060.pdf
States batteries are not replaceable, which means that they are buried somewhere inside the main module. Proceed at your own risk.
3/2/2015 10:13:40 PM •
Evenflo...
Answered
on Mar 02, 2015
How do I attach the
The seat back should be screwed securely to the other half of the plastic seat ring. Position cloth seat over seat back, lining up red diamond on cloth seat with inverted 'V' notch on lower edge of the seat back. The plastic tab and elastic straps go around outside of seatback and back through the narrow space between the two parts of the plastic seat. The elastic loop then hooks around the tab on the underside of the plastic seat ring.
3/25/2011 1:01:27 AM •
Evenflo...
Answered
on Mar 25, 2011
