20 Most Recent Panasonic KXTG2344 Cordless Phone Questions & Answers
My answering machine for my Panasonic KX-TG2344 won't pick up
Sound like you answering machine is shot. Replace the main base unit and that will solve your problem. When you replace it you will have to re-register the handsets.to the new, base it is a simple two action process and easy to perform. They are pretty cheap on eBay. $15.00 to $20.00 at most
5/5/2017 3:54:10 AM • Panasonic... • Answered on May 05, 2017
2answers
Panasonic KXTG2344 Phone 2,4ghz malfunction with microwave
You can change the channel used by the phone in the settings, but the better option is to make sure the charger base is nowhere near the microware.
Also, make sure that the microwave and the charger base are NOT plugged into the same outlet. I would even try a different outlet than you are using now as interference would definitely pass through the line.
2/28/2013 7:02:40 AM • Panasonic... • Answered on Feb 28, 2013
0answers
2answers
Panasonic cordless phone: Model#KXTG7624 I dropped
hi welcome to fixya since it was working fine before but due to accidentally dropped that is why you can not hear now anything like the dial tone so here is my solution first try to reset remove the battery and re install. then if still the same problem your next step is you are going to check the internal part to gain access the ringer speaker, now check the speaker might be damage at the same time check loose wiring and contact to the terminal of the speaker re soldered if needed .make sure you remove the battery while doing this to avoid not to damage other part. hope this will solved the problem thanks for consulting through fixya good bless.
8/25/2011 9:43:16 AM • Panasonic... • Answered on Aug 25, 2011
Both phones in the set
We have a Panasonic that is starting to go stupid. After 4 or 5 years, with a fully charged battery we register it but it only stays registered for about a day or two. If yours is acting the same way, well cordless phones aren't that expensive anymore.
Mine is the cute red one.
Carl
2/7/2011 7:44:22 AM • Panasonic... • Answered on Feb 07, 2011
Cordless phone has error message
the get closer to base message displays when you are too far from the phone's docking station. It could be as simple as replacing the battery with a new one from radio shack or such electronic places. But then again I don't know if it was damaged, dropped, or got wet, so this is my most reasonable solution.
12/10/2010 4:34:37 PM • Panasonic... • Answered on Dec 10, 2010
One of our phones says go closer to the base, it
try re-registering the phone, this symptom is typical of a phone that has lost its registration with the base unit
12/8/2010 2:32:18 AM • Panasonic... • Answered on Dec 08, 2010
The main phone says no link to ac adapter and the phone isn't wor
i think the linking circuit is been faulty if possible go & repair it
7/4/2010 12:15:02 PM • Panasonic... • Answered on Jul 04, 2010
How to reset the alarm ?
here i attached the link for the manual of KX-TGA931T
http://www.scribd.com/doc/4242810/Panasonic-KXTG5050W-58-GHz-Cordless-Phone-Manual
5/17/2010 2:13:12 PM • Panasonic... • Answered on May 17, 2010
Phone cuts off after 20 minutes
Check your battery level after talking for 10 or 15 minutes. Your battery could be weak and you might need to replace it if you see the bars dropping after using for a period of time.
1/14/2010 11:27:32 PM • Panasonic... • Answered on Jan 14, 2010
The answering system is not picking up messages I
Just spent a bit more time and resolved the issue by changing the number of rings before the answering machine comes on, thanks for your assistance.
12/4/2009 1:44:15 PM • Panasonic... • Answered on Dec 04, 2009
2answers
How do you know when your batteries need replaced
1. call length is diminished
2. battery takes a long time to - or never fully - charges
3. Handset will not turn on.
4. Handset gets hot during use.
5. Approximately 2 years of regular service.
Any of these indicate it is time to replace it.
Thanks for using Fixya - a 4 THUMBS rating is appreciated for answering your FREE question.
10/4/2009 6:48:56 PM • Panasonic... • Answered on Oct 04, 2009
How to retrieve voice mail from another phone
The factory preset code is "11".
Call your phone from a touch tone phone. Enter your remote code (11, or whatever you set it to) during the greeting message. The number of new messages will be heard, and the new messages will be played.
8/28/2009 1:58:14 PM • Panasonic... • Answered on Aug 28, 2009
Both phones say "line in use
You might try removing the batteries and unplugging the base unit. That will reset the system to factory settings. You will have to reprogram the system.
8/28/2009 1:36:08 PM • Panasonic... • Answered on Aug 28, 2009
Panasonic KX-TG2344 acidental erased message
Sorry, there is no way to undo an erased message.
1/14/2009 9:11:57 PM • Panasonic... • Answered on Jan 14, 2009
2answers
No link to base
The solution works!
Thanks.
11/7/2008 6:05:03 PM • Panasonic... • Answered on Nov 07, 2008
0answers
Panasonic KXTG2344 Cordless Phone Logo
46 questions posted
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Lands Phones
Most Popular Question
know when batteries need replaced
  • Lands Phones
