20 Most Recent Clymer Indmar GM V-8 Inboards 1983-2003 Questions & Answers
Assume you are checking the max RPM when not operating the boat? If so, might have a second tach to check the gauge is okay. Naturally, if you checked RPMs underway it would probably be a dented prop. Pete
Clymer Indmar GM... | Answered on Nov 30, 2019
Check out the following links, these are specs and manuals:
http://www.bakesonline.com/images/MediaLibrary/IndmarIgnitionTiming.pdf
http://www.aquamarina.co.il/userfiles/file/Service/User%20Manuals/Indmar%202011%20Operator%27s%20Manual.pdf
Clymer Indmar GM... | Answered on Mar 18, 2013
Red battery positive
Red purple, switched positive
Yellow red startermotor connect to positive to start )
Purple white choke (connect to positive to choke)
Black yellow stop circuit ( connect to negative to stop engine )
Black battery negative ( for stop circuit )
Clymer Boating | Answered on Oct 04, 2017
The power supply is common for all the coils.
Have you switched the coils (wires marked 1 and 2)? If still the same coil non sparking, replace that coil.
If the same output non sparking, check the pulser coil for that cylinder. Invert both pulser coil connections (white red and white black). If the miss is on the same cilinder, replace the cdi. If the miss is on the other cylinder: replace that pulser coil.
I think you have to look at a fuel supply problem. Clogged carbs or bad fuel pump...
Also have a look at your spark plugs...
Clymer Boating | Answered on Sep 25, 2017
clean carbs and check set up !
Clymer Boating | Answered on Jun 04, 2014
Hello. You have two springs in carburetor and one in Magneto roto. No spark I pick the Magneto. For complete brake down illustration I suggest Sears parts on the web. Good luck & happy fishing.
Boating | Answered 2 days ago
NONE OUTSIDE OF THE BOAT ONLY GAS FILLER THERE
Boating | Answered on Jan 09, 2020
This is probably the best route to take. Get the Service Manual if you intend to do your own servicing.
https://www.marineengine.com/manuals/seloc/online-manuals/johnson-evinrude-outboard-manual-online.html
This shows wiring thumbnails but don't lead the the wiring diagram
https://www.google.com/search?q=evinrude+e25telcnb+solenoid+wiring+diagram
Boating | Answered on Jan 08, 2020
Tightening clutch on capstan should fix the problrm
Boating | Answered on Jan 05, 2020
Brand new... thats why they have warranties
Boating | Answered on Dec 15, 2019
4600 lbs.
IF IT DROPPED PERHAPS 1/2 INCH THE SHIFT ROD NEEDS DISCONNECTED .
Boating | Answered on Nov 30, 2019
GO SEE YOUR LOCAL DEALER FOR ASSISTANCE
Boating | Answered on Nov 24, 2019
MEASURE IT AND GET SMARTER FOR YOURSELF
Boating | Answered on Nov 23, 2019
Clymer Indmar GM V-8 Inboards 1983-2003 Logo
2 questions posted
Top Clymer Boating Experts
Colin Stickland
Colin Stickland
Bruce
Andrew Taylor
Andrew Taylor
Are you a Clymer Boating Expert? Answer questions, earn points and help others
View Most Popular
Clymer Boating
  • Clymer Boating
Most Popular Question
not getting max rpm 350 marine inboard
  • Boating
