20 Most Recent
Panasonic CW-XC143EU Air Conditioner Questions & Answers
Need Recharge?
Make sure your AC is set to cool and not dehumidify . If yes try lowering the temperature , if still no cooling then yes you probably nee to recharge
6/27/2015 6:01:27 PM •
Panasonic...
Answered
on Jun 27, 2015
When you switch to compressor it just hum, motor
It's because of compressor taking high amphs. Due to weak of capacitor, or loose wiring. And also piston inside the compressor struck. Replace capacitor and try after rectifying loose wiring, if any.
12/15/2010 4:14:36 PM •
Panasonic...
Answered
on Dec 15, 2010
Fan blows but a/c not cold at all
Normally, this is due to a shortage of gas or if the condenser fan motor is not running. If after a while, when the aircon is switched on and you can hear the compressor running, then you know the fan is defective. If compressor and fan both dont switch on, then it normally indicates a gas shortage.
8/15/2010 8:03:46 AM •
Panasonic...
Answered
on Aug 15, 2010
Panasonic inverter air conditioner error code h11 pls help
Assuming you have a mini split and not a VRF system (although it is possible the error codes are the same),the h11 code typically indicates a communications problem between the indoor and outdoor units. This could be due to loose or broken wiring, a bad connection at either end or possibly a bad communications board in either the indoor or outdoor unit.
10/11/2021 7:39:18 AM •
Panasonic...
Answered
on Oct 11, 2021
What is error code h55 in panasonic floor mounted ac E28NFQ?
H55 error comes from the window that has not properly function to open, you must have off the breaker of the unit then, remove the upper window and check if the motor is not parallel to each both side, then return it and switch the breaker and turn on the unit
9/23/2019 2:44:00 AM •
Panasonic...
Answered
on Sep 23, 2019
How to reset timer flashing CS-PC12MKH
That's indicating that an error has been detected and you need to put the remote into service mode to find out what the error code is. You will have to repair the fault before it will return to normal operation.
5/22/2019 11:38:41 PM •
Panasonic...
Answered
on May 22, 2019
