20 Most Recent
Buck 97-01 Toyota Camry Inside Door Handle Case Right Tan Questions & Answers
99 camry 4cyl w/773 code. Can anyone help me ?
Sl solonoid is next to kickdown cable going into transmissin
plug in two 10 mm bolts hold it in place easy to fix
ater replace take battery post reset compitor
have a nice day easy to fix
Po773 code on a 97 camry
I just figured what PO773 code is. It is the Torque converter lock up solenoid. The solenoid has 2 bolts that can be undone from the top of the car. The solenoid is located behind park neutral safety switch. The plug has a pink with black strip. This is A140E transmission. The problem with the vehicle was the Check engine was on and the RPM would not drop 300 RPM on the freeway at cruising speed. I only post this answer because the only thing I could find in the web was the lock up solenoid was on the valve body. Toyota calls this solenoid #3.
BRAKE LIGHTS DON''T WORK
The brake pedal switsh will be way under the dash, almost where the pedal meets the firewall. It will have either two seperate wires or a connector attached to it. If you disconnect this and put a small piece of wire in-between the wires and your brake lights come on, it it the switch.
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
