20 Most Recent
Sonic RecordNow! Deluxe 7.3 Questions & Answers
Why does my sonic now not let me record DVD's?
if you are trying to copy dvds that are copyright protected the program knows that and won't let you
there is also a compression issue you have to use a large volume disk to copy some /most movies over 4.7 gig
heres what you do go to dvd-hd decrypter and down load the free version then go to dvd shrink and down load that program this will allow you to decrypt and to shrink you dvd,s to the 4.7 gig
then you can copy them
I downloaded an .iso file
did you mount the ISO to your hard drive. and if u need something from the .msi file, just change .msi to .txt please vote for me helping you!
Installing my Sonic Record Now
Does it say any driver specifically is missing? Can you write down the actual error you are getting and send it to me in here? Do all other programs function correctly? It may just be a compatibility issue with Record Now... I am checking into this, please respond back with a little more info on the error.
Thanks
Tim
I don't have a sound in windows 7..how do i make
Check the Device Manager in the Control Panel to see if the audio device is installed properly.
Could be that you need to (re)install the
sound driver.If it is only online sound that is a problem, you might need to reinstall the Abobe Flash Player or Apple QuickTime.
I need driver/drivers for Sonic
Sonic RecordNow Deluxe 7.3 is an old burn software which do not need any drivers to run the program. If your New PC is running on OS Win 7, the software is not compatible with Win 7 & Vista. The version 10 is compatible.
Hope it helps.
Trying to copy a DVD--when I insert a blank DVD,
1. your DVD blank may be rejected due to the program compatibility.
2. the DVD that is being copied was burn at a certain speed and this may have an affect on the
copy of the original.
3. the blank DVD should have the same capacity as the original or better that is if the
DVD blank has the capacity of 4.5 GB and the original is 8.5 GB then the copy has
reached it's capacity and will be ejected by the DVD burner.
I hope this helps. Have a great day.
I am not able to burn a cd
If you are unable to burn the CD it could be due to software, Hardware or system compatibility problem
As you have not provided any detailed error code and operating system that you are using, hence I would suggest you to first check the minimum system requirements as follows:
Minimum System Requirements:
* Microsoft® Windows Vista™ (32- or 64-bit), SP1 is required, Windows® XP SP3 (32- or 64-bit), Windows® 7 Home Premium, Professional or Ultimate (32-or 64-bit)
* 1 GB of free hard disk space for typical installation of all components
* 1024x768, 16-bit color graphics card
* 16-bit Windows compatible sound card and speakers
* DirectX 9.0c or higher compatible sound card and graphics card
* Windows Media Player 10 or higher
* Microsoft Internet Explorer 7 or higher
* CD or DVD drive to install the software (for physical version only)
* CD or DVD recordable drive
Also, If you were unable to burn CD earlier with the same software however the problem started recently, the I would suggest you to perform the following action:
# Check the CD/DVD driver on your System from device manager
# Try to change the media (most of the time problem come from the writable disk that you might be using)
Restore the system to an earlier date if it was working earlier
To perform system restore...click on start...then go to all programs ..then click accessories ..then system tools and then system restore
Select a previous date highlighted i bold when it was working and click next...
If this is the first time you have installed the software, then problem could also be with software configuration
Try to burn the CD directly without using the Sonic software (directly from windows explorer)
Open Folder with contain the music file, right click on a particular file and click on send to... select you DVD/RW drive and try to burn it
Let me know the result...if you require further help...also if possible let me know the make and model of your system along with the operating system that you are using and error code in specific
Thanks
Record Now Used Up All Hard Drive Space I have no
Do you not know the admin password to your OS? That's a problem when your apps leave 8GB staging files around in their application files.
What's the problem with deleting the larger files in the directory you mentioned? They all should be project files (hopefully some committed to disc successfully? And no longer of use?)
Temp files are a common issue. You can go into the settings for that application (RecordNow! Dlx.) and tell it not to keep all those files! You can run a temp file cleanup utility for WinXP or Vista or Win7 or whatever....
How do i remove unwanted downloads from my
If there is an Icon on the Desktop? "Right click and select to uninstall", follow instructions, restart the computer." Go to Start Menu click on the Control Panel Icon, next select,(" Uninstall Programs / Software, highlight the item, and click to uninstall; restart the computer.
