20 Most Recent
Metra 95 96 Chevy Truck Questions & Answers
Tail light fuse on 95 chevy truck keeps blowing .
Check and clean grounds make sure there are no crack insulators or fractured wire, if there is cut, solder. Reduction in wire surface area causes resistance, which causes fuses to heat up and pop
How to install glow plugs on 1996 K3500 6.5 diesel
Fairly easy on driver's side as they are very visible. Just unplug the harness for each plug and set it above the plug. Use a deep well socket that fits the plug (use a new one to ensure you have the proper size) and remove the old ones. Apply some anti-seize to the threads of the new plugs before youput them in. This will help with removal in the future. Install all the new plugs and re-connect the plugs to the harness.
On the passenger side, you will need to remove the tire and the inner fender skirt to reach the back 2 plugs. Be sure you block the vehicle to prevent it from falling and do not rely on just the jack. Follow the same procedure as above and it should fire right up.
**Be sure to check each old plug to ensure that none of the tips melted or broke off in the cyclinder. It will be obvious if one is broke.**
Shakes when I put on the break
If your truck is shaking when you apply the break. There is a good chance that your rotors are warped. If you take them off, and take them to a shop that cuts rotors. They may be able to fix them for you. If not they will need replaced
I have changed out fuel injectors wires plugs cap
some of these 1500 series trucks had bad computer flashing, locate a used computer from the local scrap yard and try it. make sure it has the same engine and options on the truck. if not then change the control module, this is what gives the plugs and coils a spark signal.
How to change evaporater 95 chevy truck
Hi and thank you for using fixya. See below for instructions in removing evaporator.
Tools needed.
AC freon holding tank and extractor
metal torch
new evaporator
freon to put back in the system
1- empty the system and save the gas inside it will deplete the ozone layer
2--take out evaporator by cutting on both end with the torch
3- put new evaporator back by uniting with blow torch both ends.
4-put your gas back on
good luck
Truck hesitates
Have you changed your fuel filter? Are you sure your don't have a bad plug or wire? Is it fuel injected? Checked fuel pressure?
How to loosen the serpentine belt in a 1996 chevy k1500
there is no way to loosen the belt in that chevy. it is a serpentine belt system with a belt tensioner that keeps the correct tension on the belt. check the belt and all the pulleys for wear. if the belt and pulley are in good shape i would suggest changing the belt tensioner.
Nakamichi NA6605 in a ford 2002 excursion the install went fine with proper harnesses Metra after installing new speakersI am having a problem with the unit going in to mute mode
The issue you're describing with your Nakamichi NA6605 head unit muting itself after installing new Infinity speakers could be caused by a few different factors. Let's go through some troubleshooting steps to help pinpoint the problem:
1. **Impedance Mismatch:** You mentioned that you replaced the factory speakers with Infinity 6x8 REF-8632cfx speakers. These Infinity speakers have an impedance of 3 ohms, while the original speakers were likely 4 ohms. This difference in impedance could potentially cause issues with the head unit's output stage. Some head units are designed to handle a specific range of speaker impedances. Make sure the Nakamichi unit is compatible with 3-ohm speakers. If it's not, this impedance mismatch could indeed lead to the behavior you're experiencing.
2. **Wiring and Connections:** Double-check all your wiring connections. Make sure that the speaker wires are properly connected and that there are no loose or exposed wires that could be causing a short circuit. Incorrect wiring can cause the head unit to detect a fault and enter mute mode.
3. **Power Supply and Ground:** Ensure that the head unit is receiving a stable power supply and that the ground connection is solid. Voltage drops or poor grounding can lead to unstable operation.
4. **Short Circuit Protection:** Many modern head units have built-in protection mechanisms that detect short circuits or incorrect impedances. If the head unit detects a problem, it might enter mute mode to prevent damage. Check the head unit's user manual to see if it has any relevant protection features.
5. **Head Unit Settings:** Check the Nakamichi unit's settings, especially those related to speaker impedance or output settings. Some head units allow you to adjust output settings based on the connected speakers.
6. **Firmware Update:** If there's a firmware update available for your Nakamichi head unit, consider updating it. Firmware updates can sometimes resolve compatibility issues.
7. **Test the Speakers:** To rule out the possibility of a faulty speaker causing the issue, you can temporarily disconnect the Infinity speakers and see if the head unit behaves differently.
8. **Professional Inspection:** If none of the above steps resolve the issue, it might be best to seek the assistance of a professional car audio installer or technician. They have the expertise and tools to diagnose and address complex issues with car audio systems.
Remember, electrical issues in car audio systems can be complex and require a methodical approach to troubleshooting. If you're not comfortable diagnosing the issue yourself, it's best to seek professional assistance to ensure a safe and accurate resolution.
