20 Most Recent
Samsung Omnia i900 i908 Premium Orange Silicone Skin Case Cover Questions & Answers
Block one number from calling and texting me
Hi
some Samsungs have a 'block list'. I am quite sure that the D900 has it. All you have to do is when you receive a text from this number select options, and you should see in sub menu 'add to block list'. I am not sure if it also blocks calls once added to the list? Hope that helps?
Can i block a number
don't believe your phone has that capability by itself and I'm unaware
of any apps that can be downloaded to it that will call block particular
numbers.
However, there is a FREE app
for Windows Mobile users that own a Pocket PC, Smart phone or Moto Q.
The program works well. (I use it myself) It's called, Call Firewall.
Call Firewall basically rejects any or all unwanted calls.
Features & Options:
a. Accept all calls, or
b. Accept call from My Contacts only - accepts calls from contacts only, others are rejected
c. Reject all calls, or
d. White List - accepts calls only from the white listed nos
e. Black List - accepts all call except from the black listed nos
f. Black List Pattern - any no STARTING from the black list pattern list is rejected.
for example if you enter "123", so all nos STARTING from "123" will be rejected
this is a very nice option with which you can block nos from any
particular network, country, city , area or whatever you can think of.
Finally there is also an option to reply with an SMS.
IMP:
1. To Delete Black list/White list Nos TAP & HOLD the stylus for a few seconds to get the options.
2. Auto start - Create a shortcut to Callfirewall.exe with 'startup' as parameter (without the '') and copy to windows/startup/
3. Please uninstall previous versions before installing ver 1.3
4. Also Delete Callfirewall.xml from the Root folder. Previous versions Callfirewall.xml will not work with version 1.3.
5. The XML file for 1.3 and 1.4 are compatible.
ISSUES :
1. One Ring Delay in Rejecting Calls.
2. Ongoing call -> Blocked Caller Calls -> Existing Call is Hung Up.
3. Problems with some Radio ROMS where the caller identification is delayed by Windows by a couple of seconds
hope this helps you
I have a Omnia i900
Strange problems with omnia regarding boot may caused ..
There is a JTAG solution for competely dead phones
Those help you to read and write boot ! where you can not do with standart tools and cables .
you can find on the net
www.omnia-repair.com
Ps : if you think it is not neccessarry to buy
i can suggest to contact and ask for help to repair your phone .
Best Regards
How to hard reset Samsung st1000 camera
To hard reset your Samsung ST1000 camera, follow these steps:
Reset Settings via Camera Menu:
Open the camera app.
Tap on the Settings icon (usually represented by a gear).
Scroll down and select Reset settings.
Confirm the reset by choosing Yes when prompted.
Physical Reset (if needed):
Locate the reset button on your camera (refer to the camera's manual for its exact location).
Press and hold the button for at least 10 seconds until the camera restarts
Samsung S9 turning Samsung Music app on by itself
This seems to be a known issue where the Samsung Music app starts randomly1. Here are a few steps you can try to resolve this issue:
Check if an app you downloaded is causing the problem: Start the phone in Safe Mode. If the problem does not occur in this mode, then you need to find out what app this is and uninstall it.
Wipe the cache partition of the phone from the recovery mode: This can often resolve issues with apps misbehaving.
Perform a factory reset: Please remember to backup your phone data before doing this. Once the reset is complete, do not install any apps in your phone yet. Try to check first if the issue still occurs.
Check Power Saving Mode: The power saving mode could interfere and block your music-streaming app if turned on.
If none of these steps work, it might be a good idea to contact Samsung's customer service for further assistance.
Why do samsung tab 10.1 when i put the sim card it goes out
- SIM Card Tray Issue: The SIM card tray might be damaged or not properly aligned. Ensure that you are inserting the SIM card into the tray correctly and that the tray is properly seated in the device.
- Incompatible SIM Card: The SIM card you're trying to use might not be compatible with the Samsung Tab 10.1. Ensure that you're using a SIM card that is supported by your device and is of the correct size (micro-SIM or nano-SIM).
- Dirty or Faulty SIM Card Contacts: Dust, dirt, or debris on the SIM card or SIM card tray contacts can prevent proper connectivity and cause the SIM card to eject. Clean the SIM card and the tray contacts with a soft cloth and reinsert the SIM card.
- SIM Card Slot Issue: There could be an issue with the SIM card slot itself. Inspect the slot for any physical damage or debris that may be causing the SIM card to eject. If you notice any damage, you may need to have the device repaired by a professional.
- Software Issue: Sometimes, software glitches or conflicts can cause the SIM card to eject unexpectedly. Try restarting your Samsung Tab 10.1 or performing a factory reset to see if the issue persists.
If none of the above steps resolve the issue and the SIM card continues to eject, it may indicate a hardware problem with your device. In this case, you may need to contact Samsung customer support or visit a certified repair center for further assistance.
