20 Most Recent
Navigon 7200T GPS NAVIGATOR PERPW/ FREE TRAFFIC VOICE ENTRY Questions & Answers
Volume up all the way not muted but not speaking?
Not sure it this is like my Nuvi but you have to select a Language with ( TTS ) ending that is Text-To-Speech .... other i aw were i thnk something that says ( Eesti )
But it should be in the Language setup
Navigon 7200t GPS Traffic Problem
Have you tried to reset the device. Probably some settings might have changed which can be easily rectified by resetting the device.
You can access the Traffic information by :
1) Tab Options > Traffic
The TRAFFIC INFORMATION WINDOW opens.
On the Navigation map, the (TMC shortcut) button can also be used to display
the TRAFFIC INFORMATION WINDOW. The TMC shortcut button displays when traffic messages have been received and are currently available.
2). Tap the Traffic information button to view a list of available traffic message types.
3). Tap on the type of messages to display.
4). Tap the OK button.
You can follow the instructions in your User guide also.
The volume isn't working on our Navigon 7210
Go to the volume screen. Tap the buttons for louder and softer. If the volume indicator does not move then goto solution A. If the indicator does move but you do not hear the voice say "louder" or "softer" goto solution B.
A. There is a problem in your settings file. You need to reset these files to factory status. This will reset all your settings to factory default. From the main screen hit Options then hit Options again. You should see a button that says "set to factory" or something like that. Click that and then reenter your custom settings as you like. Problem fixed.
B. You have a hardware problem. Call Navigon support for repair options.
Where to obtain a users manual
Here is the link to it!
http://navigonusa.com/_pdf/manual/Manual_7200T_English_Rev1_1.pdf
You will need Acrobat Reader on your PC to read,
Please Rate!
