20 Most Recent Alpinestars Craig Snapback Hat Red Questions & Answers
go to manuals.com. see if it is there.or go to craig.com. lol.
Alpinestars... | Answered on Mar 26, 2017
Hi Tiffany the best thing u can do is youtube go to the website and type in blower motor replacement and there are tons of videos but there all not going to b the same but I'll bet there's one for your car have a grand day regards Chris
Motorsports | Answered on Dec 21, 2018
Once you have disassembled the motor and pulled the armature from the field windings you will need to have an ohm meter. Set the meter to OHMS and then touch the red lead to the winding lead on one end and the black lead to the winding on the other end and if the windings are still good you should be a 0.00 reading or very close depending on the resistance. The reading should be close to the same as touching the red and black leads together. This means that there is a complete circuit end to end and the winding is not broken. IF the meter does not give you that reading you will have a broken winding.
Motorsports | Answered on Oct 29, 2018
Check all fuses and if good you will have to pull the covering from the rear hatch to get at the wires so you can check with a test light or volt meter to see that you are getting voltage when the wiper switch is activated. If there is no voltage try to see if the wire is damaged somewhere or if the switch itself has gone bad. If there is voltage them the motor may be burned out. You will have to have the things that you find replaced if bad.
no, it is per car, not per team surely. Here is some reading for you.
Competitors are allowed only a limited number of tyre sets during a race event: thirteen dry, four intermediate, three wet. Each tyre must be marked with a unique identifier for tracking and scrutinising during a race event. During the practice sessions drivers are limited to the use of three sets of dry tyres, and certain sets must be returned to the supplier before the second and third sessions. If qualifying and starting the race on dry tyres, drivers who complete a lap during the third period of qualifying (the top ten) must start the race on the tyre set with which they recorded their fastest time during the second period. Any cars that qualified outside the top ten may start the race on any remaining set of tyres. Cars must race on any two dry compounds during a race unless intermediate or wet tyres have been used by that car in that race.
If driver crashes out can he give his remaining tires to team mate Google...
Formula One regulations
Motorsports | Answered on Jul 29, 2018
If my memory serves me correctly the dash needs removed (hard work) and work then easy
Motorsports | Answered on Feb 04, 2018
great mercadolibre com mx http://www.soccerphysicsonline.com/
Motorsports | Answered on Jan 15, 2018
you need to post what engine you need firing order for
Motorsports | Answered on Nov 30, 2017
Check for a bad fuse..not sure where it is but look in the owners manual or inside cover of the fuse panels for the wiring diagram
Motorsports | Answered on Sep 14, 2017
The alarm you hear may be the overheating alarm... but, if it is, it won't run too long with it on before the engine locks up...Is there evidence of water coming from the witness hole in the back of the motor? Good.. otherwise,, you may be hearing the low oil alarm..or the oil pressure alarm...My bass boat oil system alarm goes off every time I crank the engine..but it uses oil and runs great...(been doing it for years - I am too lazy to clean the sensor in the oil tank)
The RPM and faster alarm is something that puzzles me?
Motorsports | Answered on Jun 14, 2017
in manal that you have recived in the car should be explained what every fuse is doing.
Motorsports | Answered on May 31, 2017
Go to a smaller exhaust or a longer exhaust (not practical. Engines need some back pressure. That is why headers on dragsters are all of equal length.
Motorsports | Answered on May 30, 2017
Believe it or not, Home Depot, whom I despise. A low/bad chip should not cause slow engine crank, if that is what you meant. Show crank is low amperage. Weak starting battery or electrical connections at either the battery or the engine.
ARE YOU SURE IT IS A FUEL DELIVERY PROBLEM? SPARK & FUEL ARE THE 2 THINGS THAT CAUSE A VEHICLE TO START AND RUN. IF IT USES "COILPACK(S) HAVE THEM /IT TESTED...LIKE AT AUTO ZONE...OTHER IGNITION SYSTEMS, MAKE SURE YOU ARE GETTING A FAT STRONG SPARK OUT OF COIL!....WHEN YOU TURN THE IGNITION SWITCH TO RUN POSITION (DON'T CRANK IT OVER)....WITH THE DRIVERS DOOR OPEN..YOU SHOULD HEAR A WHIRRING SOUND MOMENTARILY FROM THE REAR OF THE VEHICLE. THIS IS THE FUEL PUMP RUNNING. IF YOU DONT HEAR A FAINT HUMMING...THE FUEL PUMP
1. IS DEFECTIVE
2. IS NOT GETTING POWER
3. YOU HAVE A RELAY OR WIRING ISSUE (UNDER HOOD MAXI FUSE AS WELL). IF NOISE IS HEARD..GO TO SPARK DIAGNOSIS JEFF GEYER (517) 489-1566 OWNER AUTOWORX
Motorsports | Answered on May 18, 2017
unencrypt the question! lol?
Motorsports | Answered on Mar 26, 2017
First of all let me tell you that it is a myth that you can not go back and forth between conventional oil and synthetic or in your case synthetic blend. They all mix very well together but why on earth would you not use a full synthetic in every thing? It will keep your motor so much cleaner, and last way longer, new or 150.000 miles used, does not matter. They refine the synthetic oils way way longer to get the impurities out. Other big thing [ OILTEMPERATURE AND WEAR COLD START UPS ] Exceeds and blows conventional out of the water. plus a real full synthetic you can run a lot longer just spin a new good grade filter on or change it. Me my self Ill run Walmart full synthetic in my grand prix and ROYAL PURPLE in my 2013 mustang. I think there all full synthetics are good compared to the old dirty sludge and if all the new manufactures are recommending it now its good. Do you have any motor rebuilders or trucking builders close to you? Just go look at the oil pans to compare the too . I guarantee you will be sold that day and never run conventional again.... PERIOD.
Motorsports | Answered on Feb 09, 2017
Call around, the one that is busy is the one you want.
Motorsports | Answered on Feb 02, 2017
call around the ford veteran and modified car clubs to see what information you can get
they are the most likely people that can help you
Motorsports | Answered on Dec 21, 2016
coudl be the speed sensor. or trans computer
Motorsports | Answered on Nov 01, 2016
Alpinestars Craig Snapback Hat Red Logo
6 questions posted
Top Alpinestars Motorsports Experts
Andrew Taylor
Andrew Taylor
chuck ringwood
chuck ringwood
Are you an Alpinestars Motorsport Expert? Answer questions, earn points and help others
View Most Popular
  • Alpinestars Motorsports
Most Popular Question
need audio tower icraig cht907 manual
  • Motorsports
