20 Most Recent Hayward H250FDN Low NOx Natural Gas Pool or Spa Heater Questions & Answers
I want to go over 104 degrees
Did you ever find out how to do the bypass? I'd like to get to 106....
9/28/2021 2:29:49 AM • Hayward H250FDN... • Answered on Sep 28, 2021
Why does my hayward h250fd have and if error code? it is a brand new heater
If the control exceeds the maximum number of ignition retries or recycles the heater will shut down and go into lockout. Automatic reset is 60 minutes. There are a few reasons that this might be happening. They range from air in the gas line to inadequate gas flow. Start by checking the installation
8/12/2014 5:39:19 PM • Hayward H250FDN... • Answered on Aug 12, 2014
Is there an alternative control panel I could use for a H259FDN?
Unless you have rigged your unit for remote control, this control panel is the only one listed. You can check this link for contact information http://www.hayward-pool.com/prd/In-Ground-Pool-Heaters-Universal-H-Series-Low-NOx_10201_10551_14002_-1_14003__I.htm
5/12/2014 3:38:24 AM • Hayward H250FDN... • Answered on May 12, 2014
Hayward pool heater display reading AC
Hayward error codes shows AC is blower vacuum switch closedhttp://waterheatertimer.org/pdf/Hayward-error-codes.pdfHayward pool manuals:http://www.hayward-pool.com/prd/In-Ground-Pool-Manuals_10201_10551_14502_-1___I.htm If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/15/2012 11:00:34 AM • Hayward H250FDN... • Answered on Oct 15, 2012
Header cracked on hayward pool lo nox h250fdn
Headers on hayward heaters are usually warranted for 10 years, except for freeze or chemical damage. You may want to contact a local warranty station to see if you can get it replaced under warranty.
5/19/2010 2:33:29 PM • Hayward H250FDN... • Answered on May 19, 2010
Heater is new, installed at grade on above ground
Adjust the switch fully in the opposite direction. If you are at 1.5 you are at the light end of the adjustment range of that switch, which can be adjusted up to 5psi. Then let it back off until it works reliably. Rarely do you need to adjust a pressure switch on an above ground pool so it should end up about in the middle of the adjustment scale.
7/10/2009 5:44:12 PM • Hayward H250FDN... • Answered on Jul 10, 2009
2answers
HF code on hayward 200fdn pool heater?replaced gas valve still have same code.What now?
HF Flame present with gas valve "OFF" error If flame is sensed with the gas valve off the control will go into lockout. The blower will run until error condition is corrected. When corrected, control will run blower for 5 s then automatically restart after 2 minutes. the error might be caused by a faulty flame sensor. i have heard of this happening the other way (carbon blocks sensor causing no ignite)
3/31/2024 9:08:14 AM • Hayward Pool &... • Answered on Mar 31, 2024
2answers
New XtremepowerUS 2HP In-Ground Swimming Pool Pump Variable Speed 2 Inlet 230V High Flo w/ Slip-On Fitting, i turned it on after 2 mins switch from high to low then shut off and get very hot.
All electric motors run hot and pool pumps are no different. But how hot is too hot for a pool pump? The first test is simply whether you can touch the motor or not. Under normal operating conditions, the motor end of the pump is hot enough that you can barely touch it - but not searing hot.Best to you.https://www.google.com/search?q=XtremepowerUS+2HP+In-Ground+Swimming+Pool+Pump+Variable+Speed+running+temp&newwindow=1&sxsrf=AB5stBhpriuNhnfXLYYTg7tuS-LWwW262g%3A1690815381903&source=hp&ei=lcvHZKH_NOHi9AOquJjADw&iflsig=AD69kcEAAAAAZMfZpVdAAi94QXZiwKfN3nArsWv-Gm1z&ved=0ahUKEwjhnd6RmrmAAxVhMX0KHSocBvgQ4dUDCAo&uact=5&oq=XtremepowerUS+2HP+In-Ground+Swimming+Pool+Pump+Variable+Speed+running+temp&gs_lp=Egdnd3Mtd2l6IkpYdHJlbWVwb3dlclVTIDJIUCBJbi1Hcm91bmQgU3dpbW1pbmcgUG9vbCBQdW1wIFZhcmlhYmxlIFNwZWVkIHJ1bm5pbmcgdGVtcEgAUABYAHAAeACQAQCYAQCgAQCqAQC4AQPIAQD4AQL4AQE&sclient=gws-wiz#kpvalbx=_sMvHZMuPJPez0PEP3M2LgAY_44
10/21/2023 2:20:52 AM • Hayward Pool &... • Answered on Oct 21, 2023
How can I test if my Hayward gas heater water pressure is working??
Testing the water pressure of your Hayward gas heater is a relatively simple process. Follow these steps to check if your water pressure is working properly:
  1. Turn off the Gas Heater: Before performing any tests, make sure the gas heater is turned off to avoid any potential accidents or injuries.
  2. Check the Pressure Gauge: Locate the pressure gauge on your Hayward gas heater. It is usually located on the front panel of the unit or near the plumbing connections.
  3. Observe the Pressure Reading: The pressure gauge will display the current water pressure. It is typically measured in pounds per square inch (psi). The optimal water pressure for most pool heaters is usually between 15 psi to 25 psi, but it's essential to check your heater's manual for the specific recommended pressure range.
  4. Turn on the Pool Pump: Ensure that the pool pump is running, as it is responsible for circulating the water through the heater. The water pressure will be at its most accurate when the pool pump is operating normally.
  5. Monitor the Pressure: While the pool pump is running, observe the pressure gauge to see if the water pressure falls within the recommended range. If the pressure is below the minimum recommended level, it may indicate a circulation issue or a problem with the pool pump.
  6. Check for Leaks: While testing the water pressure, inspect the heater and the surrounding plumbing connections for any signs of leaks. Leaks can lead to reduced water pressure and affect the heater's performance.
7/23/2023 2:15:40 PM • Hayward Pool &... • Answered on Jul 23, 2023
What is a 1F code on the hayward pool heater
The code you are referring to is actually IF, not 1F. It stands for ignition failure. If the control exceeds the maximum number of ignition retries or recycles the heater will shut down and go into lockout. Automatic reset is 60 minutes.
7/5/2023 3:31:36 PM • Hayward Pool &... • Answered on Jul 05, 2023
Do i need the flow controller
4/13/2023 7:58:25 AM • Hayward Pool &... • Answered on Apr 13, 2023
MaxFlo VS 500 variable-speed pool pump. Where can I buy a Century Maxflo VS 500 motor fan please?
Question edited for a lot more clarity Question moved from Cars and Trucks. The pump appears to be made by Hayward, yours just has a Century badge on it. The fan doesn't appear to be a replaceable part, so try Hayward direct. https://www.google.com/search?q=maxflo+vs+500+parts ..
3/29/2023 5:26:14 PM • Hayward Pool &... • Answered on Mar 29, 2023
Hayward H250FDN Low NOx Natural Gas Pool or Spa Heater Logo
Popular Tags
16 questions posted
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
john h
ZJ Limited
ZJ Limited
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Hayward Pool & Spa
  • Hayward Pool & Spa
Most Popular Question
alternative control panel could use
  • Pool & Spa
