20 Most Recent
Panasonic NN-T783SF 1350 Watts Microwave Oven Questions & Answers
Left Microwave on while empty
Hi James, Well it sounds to me as the Magnatron burnt out. There are tests you can so, so to familiarize you with what it looks like by copying the link.
http://www.ebay.co.uk/itm/PANASONIC-INVERTER-MICROWAVE-OVEN-MAGNATRON-2M236-M42-NN-SF550W-1000W-/262200547027?hash=item3d0c5ed6d3:g:ucsAAOSwSHZWdkWb#ht_1687wt_726
If you are prepared to open up the unit there are a couple of checks you can do on the mag. If you see the item described above in your microwave, chances are its that. With all the video's readily available to view there is little or no point in my describing to you for what to do next so I will advise you look at 'YT' and search for 'TESTING A MAGNATRON' This should hopefully lead you to the conclusion that your Magnatron is faulty.
If it is not, then there is a possibility that the door switches could be at fault, but it's best do do this in a step by step approach to eliminate the issue.
WORD OF WARNING: I have studied electrics but even with my knowledge I received a 250v JOLT across my body due to being careless. I touched the case at the same time as the LIVE in the microwave. DO NOT MAKE MY MISTAKE. IF YOU do not feel confident to remove the cover on the microwave, then DON'T and if you do then then MAKE DOUBLE SURE IT'S NOT PLUGGED IN. I won't forget so easily If fix another.
::((((( . BE SAFE.!!!
4/3/2017 11:51:16 AM •
Panasonic...
Answered
on Apr 03, 2017
T783sf sparks from turntable coupling
No it is not safe to use, the windings of the motor are shorting against the coupling, solution! the turntable motor must be replaced in order to resolve the situation.
6/20/2012 2:04:51 AM •
Panasonic...
Answered
on Jun 20, 2012
Microwave Panasonic NN T551 new does not start even after pressing clock button , no display to set clock . Icon comes only. As : after pressing stop button. No other button gives any response
It seems like you're experiencing an issue with your Panasonic microwave oven NNT551. If the clock button is not responding and you only see two dots when pressing the stop button, there might be a few things you can try to troubleshoot the problem:
- Power Cycle the Microwave:
- Unplug the microwave from the power outlet.
- Wait for about 30 seconds.
- Plug it back in and try setting the clock again.
- Check for Child Lock:
- Some microwaves have a child lock feature that can prevent certain buttons from functioning. Check your manual to see if your model has this feature and how to disable it.
- Reset to Default Settings:
- If there is an option in the manual or settings to reset the microwave to its default settings, try doing that.
- Inspect for Physical Damage:
- Ensure there is no physical damage to the control panel or any other part of the microwave that may be affecting its functionality.
1/26/2024 4:53:36 AM •
Panasonic...
Answered
on Jan 26, 2024
How do I cook an individual frozen pie in my Panasonic convection/grill/microwave
To cook an individual frozen pie in your Panasonic convection/grill/microwave, you can follow these steps:
Preheat the oven to 375°F.
Remove the pie from its packaging and place it on a microwave-safe plate.
Place the plate in the center of the microwave and close the door.
Press the "Convection" button on your microwave and set the temperature to 375°F.
Set the timer for 25 minutes.
Press "Start" to begin cooking.
After 25 minutes, check if the pie is cooked by inserting a toothpick into the center of the pie. If it comes out clean, your pie is ready! If not, continue cooking for another 5-10 minutes until it is fully cooked. This is a general guide and there might be variance with your particular device.
10/22/2023 4:43:39 AM •
Panasonic...
Answered
on Oct 22, 2023
