20 Most Recent
NRS Hoveround Technique Used Electric Wheelchair Questions & Answers
Will this model fold down
You can release the lever on the side of seat back to fold the seat back forward to that is lays flat on top of the seat bottom. That should give you clearance to transport the power chair inside of a standard van.
Chair will power up, however
jfinch sorry it took so long to answer. If all the lights are blinking check to make sure that the freewheel levers are in drive mode. then check (if you have the power seat option ) that the seat is all the way down, and finally the problem could be in the controller check to make sure that the cable connection to the controller is well seated. If all these are correct and you still get the error then you will have to contact Hoveround tech support to find out what else you can do. They might have to send out a tech to look at the chair. Sorry I couldn't give you a quick fix Hope this helps you
Charger will not recharge battery does this mean I
you need to have your battery load tested if there is a short in the battery it could trick the charger into thinking that the charge if full, i normally use a 100 amp tester on 33 amp batteries. look in the phone book for a batteries plus in your area they may be able to help and may have the batteries you need, be ready batteries are around $100.00 depending on the size and some units have 2
Can a 33amp hour battery be used in a mpv5hoveround
If it is a 12 volt Size U1 - yes. (UB12350, GPC1234, GPL-U1, NP33-12B)
The amp hour rating is dependent on use and manufacturer of the battery. It is the size and voltage that matters. AGM batteries generally have a slightly lower AH rating but recover better from deep deep discharging cycles. (Available at marine stores)
The amp-hour rating affects how long the chair will travel between chargings.
Hoveround technique rwd motorized chair charge
Normally the power chairs will not operate when connected to the charger. If you mean the controller comes on when connected to the charger but it wont come on when the charger is disconnected, I would test the batteries first, then the connections and fuses. Did a technician inspect your power chair to determine a controller was needed, or was that just a guess by the representative over the phone? If your insurance will not cover the repairs, I would recommend spending $50 for a technician from Hoveround to come out and inspect the chair to determine what is needed to fix it so you know for SURE. It may be something simple and inexpensive.
How many protein bars should I eat per day?
Go with whole food proteins or quality whey shake. Make sure you know what you are eating, Cliff is probably one of the highest rated ones, so two bars would be fine along with normal meals. Whey protein is a naturally complete protein, meaning that it contains all of the essential amino acids required in the daily diet.
Whey protein is a rich source of branched chain amino acids (BCAAs), containing the highest known levels of any natural food source. BCAAs are important for athletes since unlike the other essential amino acids, they are metabolized directly into muscle tissue and are the first ones used during periods of exercise and resistance training.
Whey protein provides the body with BCAAs to replenish depleted levels and start repairing and rebuilding lean muscle tissue.
How often should I visit my dentist?
Most adult and children visit the dentist for regular
checkups and cleanings every six months. People at greater risk should have
checkups more often.
