20 Most Recent
Yard Machines Snow Blowers. 21 in. Single-Stage Gas Snow Blower Questions & Answers
My countax 300 will not start there is nothing
First check the safety switch under seat is working by bridging the gap.Try the same with the safety switch on hand brake.Check fuse hasn't blown.Check spark plug is intact and cable is correctly fitted.Check in line fuel filter.Ensure battery is fully charged, a drop in output will result in not starting.Hope this resolves the problem.Gareth
Y4700 EC Remove the spool assembly
there should be a place right below the spool to either put a screwdriver or a wrench in and you will turn the spool like a nut to get it off
