20 Most Recent
Electric York / Paragon A-111-20 Heat Pump Timer Questions & Answers
Heat pump iced up, totally.
It is winter here and
I have no idea if this will work, but can you turn on the air conditioning for a few minutes?
If this is a refrigeration heat pump, by turning on the A/C the coil will get warm to try to remove heat from the house.
Gary
Furnace blowers continues to run after reaching temp
It actually sounds like you may have answered the question yourself. If the mercury isn't breaking contact, then obviously it's still calling for more heat. This is a common problem with the old mercury thermostats and are usually replaced with digital ones that are way more accurate. The are fairly cheap at Wal-Mart and such, and replacing one is basically all color coded.
