20 Most Recent
Swanstone KSLS-3322 Double Bowl Kitchen Sink, Black Galaxy Questions & Answers
How would the swanstone kssb-3322-015
They will always look great with any back ground of counter top due to their unique look and under slab mounting.........Great choice........Hope this helps.
4/20/2011 7:06:35 AM •
Swanstone...
Answered
on Apr 20, 2011
The hold downs on the bottom of the sink do not
Depending on the material that your counter top is made out of there are several options.If it is wood composite with a laminate covering you can mark the location of each hold down with the sink in place then remove the sink. Carefully use a high speep drill bit to drill a series of holes at each location beingcautious to stop at least a 1/4 inch less then the minimum depth required for clamps and then use a very sharp wood chisel by hand to remove material to fit.
If your countertop is corian or other man made composite you can use pure silicone caulking as it is an excellent adhesive when cured.It will take a minimum of 24 hours to set and 7 days to cure. You will need to be careful if you use silicone because it needs to have all excess cleaned up in a hurry or it will be difficult to clean . If you have a pretty good fit between sink and counter top I would use just spot applications and try to leave room for finish caulking after silicon cures. I use a product called polyseamseal for final caulking as it is latex base and you can get a very nice finish and it cleans up eassily. It is also a good adhesive when it cures.
Check manufactures recommendations as several will only honor warrenty if silicone is used. I hope this helps you. Thanks
1/14/2011 3:46:31 PM •
Swanstone...
Answered
on Jan 14, 2011
I have a lovely Swanstone kitchen sink that got a
if the filler can be easily removed then it wasn't cleaned and dried properly.
try it again, be sure to remove ALL the sanding dust from the surface and inside the chipped area.
be sure to get the correct color, some colrs are close, but slightly different when dry
8/15/2010 6:40:13 AM •
Swanstone...
Answered
on Aug 15, 2010
Swanstone sink with chip near
Unfortunately Swanstone does not have a repair kit for this type of damage. The chip will be permanant. They do offer a limited lifetime warranty which if a defect is found they will repair or replace at their discretion. Of course you will be responsible for any labour cost as per their warranty and they do not go into any detail on how to repair impact damage. For more information go to
www.theswancorp.com
