20 Most Recent Heritage Kingston Plus 100-3-208 Stroller Questions & Answers
Kingston Heritage Stroller need assembly instructions/parts list
I have the directions to assemble if you still need them.
5/22/2014 2:34:55 PM • Heritage... • Answered on May 22, 2014
Took off material and can not get it back on
Hi Sherry We would recommend you contact Evenflo for assistance. Contact Us
2/2/2014 10:47:29 AM • Heritage... • Answered on Feb 02, 2014
I need a wheel/tube for heritage Kingston pram
did anyone respond to you? I have the same problem - need the company website or something to order a 10" tube for two of the wheels. Please let me know if you see this
10/7/2009 7:29:19 PM • Heritage... • Answered on Oct 07, 2009
I have a hand me down heritage Baby cache crib and started setting it up and it is missing the 3/4 inch 20mm well nuts-where can I find these? Tried to reach company no answer-due anytime baby!!!
Teke an existing 3/4 Inch 20mm nut off then you have to go to your local loews or home depot and have one of there associates match the nut up. If the nut is not self locking tightening it up tight then add clear gorilla glue at the end should do the job.
4/2/2019 5:47:16 PM • Heritage Baby... • Answered on Apr 02, 2019
Tyre back on wheel?
onto the rim or onto the shaft ? if you can't get the rubber tire onto the rim itself.... heat it by putting it in hot water... then try.
3/26/2009 2:41:27 PM • Heritage Baby... • Answered on Mar 26, 2009
Need conversion set for koala crib 1900R
Need interaction manual for koala baby crib model number 1900R
4/3/2024 11:41:43 AM • Baby Gear • Answered on Apr 03, 2024
I need the 2 solid metal dowels for the drop down rail to ride on
All question need full 'make model (what it is)' as first 3 words. Impossible to guess what this is? Normally if you Google make model parts you will find the items. ..
3/27/2024 5:41:05 PM • Baby Gear • Answered on Mar 27, 2024
Who has good methods to select a good coil spring mattress?
Coil spring mattresses are the best mattresses. They're bouncy plus relives pressure points. Thus, reduce pain and gives a soothe sleep. A person who is deprived of peaceful sleep due to back pain or spine ache can prefer this. I have used coil spring mattress from multiple brands but perfectly satisfied with wakeup's mattress. Click here : https://mywakeup.in/
3/27/2024 2:33:42 PM • Baby Gear • Answered on Mar 27, 2024
Pottery Barn Pocket Watch desk clock - how to replace a broken clock movement mechanism?
Mini quartz clock movements https://www.google.com/search?q=quartz+clock+movement+replacement Or ask the maker if they can supply the part.
Pocket Watch Clocks
Pottery Barn https://www.potterybarn.com > products > pocketwatc... Pocket Watch Clocks · Case is crafted of brass. · Features quartz movement that ensures accurate timekeeping. · Subtly stylized black Roman numerals stand out . ..
2/20/2024 5:52:50 PM • Baby Gear • Answered on Feb 20, 2024
Instructions to assemble Little Folks Crib. Model 1213 93 267. Thank you.
1992 Simmons Little Folks Crib Disclaimer
.:: GEOCITIES.ws ::. http://www.geocities.ws > mr_alejo > 1992_Sim... PDF May 6, 2005 - This guide is for a 1992 Simmons Little Folks Crib. The year is the two-digit number following the model number (see label on the headboard):. " ... 6 pages
ASSEMBLY INSTRUCTIONS FOR SIMMONS CRIB
.:: GEOCITIES.ws ::. http://www.geocities.ws > mr_alejo > Manufact... PDF Position the bar (7) so that bracket (4) screws are in the small part of keyhole and tighten screws firmly with a screwdriver. Attach second stabilizing bar (7) ... ..
1/30/2024 4:20:16 PM • Baby Gear • Answered on Jan 30, 2024
Model 121393267 little folks crib assembly!
No question ...............................
1/30/2024 4:04:10 PM • Baby Gear • Answered on Jan 30, 2024
2answers
I have an instep single jogging stroller and at a
Hi AshleyWe would recommend you contact InStep for assistance
1/22/2024 8:15:28 AM • Baby Gear • Answered on Jan 22, 2024
Hiw do I get the back off a pottery barn pocket watch clock that has no screws.?
With tread you see dents round the back cover, where an adjustable tool with three pins that could be adjusted to size fits in. When there is no such sign there must be a small latch where a very thin knife goes under and I wish you best of luck, not to break the knife or hurt your self with it. The back should also suddenly break loose. It is not for every body to try attempt this. Wear glasses and gloves. Look for the very thin rubber seal that makes the watch more or less water resistant. It has to go back in place and keep it on when you can.
1/14/2024 9:41:01 AM • Baby Gear • Answered on Jan 14, 2024
2answers
I need instructions for Natart Rustico to make a crib and to make a bed All parts disassembled and mixed A parts list for each would be great also
I'm sorry, but I don't have access to specific assembly instructions or parts lists for the Natart Rustico crib and bed. However, I can provide you with some general guidance on assembling cribs and beds based on common practices. Please note that these instructions are general, and you should refer to the specific assembly manual that came with your Natart Rustico furniture for accurate details.
General Steps for Assembling a Crib:
  1. Sort and Identify Parts:
    • Lay out all the disassembled parts and sort them according to their shapes and sizes. Identify key components, such as crib sides, mattress support, hardware, and any decorative elements.
  2. Follow the Manual:
    • Refer to the assembly manual that came with your Natart Rustico crib for specific instructions. The manual typically includes step-by-step guidance and illustrations.
  3. Assemble the Frame:
    • Start by assembling the main frame of the crib. Connect the crib sides to the headboard and footboard using the provided screws and bolts.
  4. Attach Mattress Support:
    • Install the mattress support platform according to the manufacturer's instructions. This usually involves attaching it to designated points on the crib sides.
  5. Secure All Connections:
    • Tighten all screws and bolts securely. Ensure that the crib is stable and does not wobble.
  6. Install Drop-Side Mechanism (if applicable):
    • If the crib has a drop-side, follow the instructions carefully to install the mechanism securely.
General Steps for Assembling a Bed:
  1. Identify Parts:
    • Lay out all the parts for the bed and identify the headboard, footboard, side rails, support slats, and any additional components.
    • Use the assembly manual provided by Natart for specific instructions. Follow the steps outlined in the manual for your particular bed model.
    • Begin by connecting the headboard and footboard using the provided screws and bolts. Attach the side rails to complete the basic frame.
  4. Attach Support Slats:
    • Install the support slats according to the manufacturer's instructions. The slats typically provide support for the mattress.
    • Ensure that all screws and bolts are tightened securely. Check the stability of the bed frame.
  6. Attach Additional Components (if applicable):
    • If there are additional components, such as decorative elements or storage features, attach them according to the instructions.
Parts List:
For a precise parts list, please refer to the assembly manual that came with your Natart Rustico crib and bed. The manual should include a detailed list of all components with corresponding part numbers. If you do not have the assembly manual, you may contact Natart directly or check their official website for customer support. They should be able to provide you with a replacement manual or offer guidance on assembly. Always follow safety guidelines when assembling furniture, and if you're unsure or uncomfortable with any step,
1/5/2024 9:29:20 PM • Baby Gear • Answered on Jan 05, 2024
4answers
Pregnancy
What do you mean by "you haven't got it". When is your period due?
I'm afraid you can't really go by "signs", as every woman is different. Some have typical symptoms and others have none. The best way to find out if you may be pregnant is to obviously take a pregnancy test. You can take an early detection pregnancy test such as First Response.
1/4/2024 3:01:20 PM • Baby Gear • Answered on Jan 04, 2024
2answers
Do you have instructions for the Cafe Kids Devon 4 in 1 convertible crib?
Try typing this information into the search engine of your computer. Fixya does not have instruction sheets. Sorry
1/2/2024 10:07:12 AM • Baby Gear • Answered on Jan 02, 2024
Heritage Kingston Plus 100-3-208 Stroller Logo
Popular Tags
7 questions posted
Top Heritage Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Heritage Baby Gear Expert? Answer questions, earn points and help others
View Most Popular
Heritage Baby Gear
  • Heritage Baby Gear
Most Popular Question
took off material not get back
  • Baby Gear
