20 Most Recent
Caroma toilet - water saving Sydney Low Profile 270 elongated 622330-609100 Questions & Answers
Why is the cistern noisy when refilling
remove lid and look where refill hose is located should be attached and in fill tube [center tube ] if it is than your toilet s noise is normal --you can knock it down a little by turning down the water pressure[turn the external valve on the water line going into toilet ] turn it a little this will also slow refill time as well --and as to ultra quiet that s for the flush mode not the refill mode
Opal 2000 toilet suite, water leaking from around
check the donut seal which seals the cistern to the pan, they perish and leak when the toilet is flushed, water runs down back of pan to floor you can check this by drying/wiping with tissue back of pan and flushing you will see if any moisture is running down there by wiping again with tissue and seeing if it is damp.
