20 Most Recent
STA-J5C09 500 Amp Jump Starter w/ 120V AC Charger, 120 PSI Compressor, 270 Degree Pivoting LED Emergency Light, 1000 Peak Battery Amps & Heavy Duty Metal Clamps Questions & Answers
My Stanley 500 1000 amp charger/compressor won't charge??
Depends how long the unit has been just 'sitting' without being used! My neighbour had a similar problem after leaving his for over a year unused. The battery that's in it simply died. In order to maintain these units in good working order they need to be used regularly - that is charged and discharged. The unit may need a new battery I'm afraid!
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
What is hashtag
hash·tag
noun
(on social media sites such as Twitter) a word or phrase preceded by a hash or pound signand used to identify messages on a specific topic."spammers often broadcast tweets with popular hashtags even if the tweet has nothing to do with them"
the hash or pound sign (#)."Hunt mistook an @ for a hashtag while tweeting derogatory thoughts about him"
