20 Most Recent
Villeroy & Boch 98M2 S1 01 Bellevue Toilet Seat & Cover White Questions & Answers
Need to remove lid on cystern
Hi im Rossouw
It depends on the kind of cystern u have. here is a few i know how to remove
1.The 2 button setting on top of cestern needs to be turned left untill it loosens up
2.The 2 screws at back of cystern lid needs to be unscrewd
3.also a 2 button cystern. has metel cabel under lid. can lift lid a littel. thast pull hard on cabel were it enters the 2 flush button meganisem
If not 1 of the above plz let me know and i will help u therder, dose are the most commen problem 1ns
plz vote 4 my advice thx
Villeroy & boch flush mechenism needs to be replaced
This problem is either two things:
1/ The water inlet valve is letting by and going down the overflow pipe. (Connected to the main centre column). You can check this by taking off the lid off.
2/ Centre column seal at the base is letting by. You can unclick the centre column by pushing the two paddles either side.
Then lift out the centre column and check the grey washer at the base. You can turn this washer around and see if this solves - if not the column has probably has a part snap off.
You can get spares here:
http://bathroomstudio.co.uk/villeroy-boch-spares/cat_131.html
I have the bellevue model and it keeps running
Your flapper is not sealing at the bottom of the tank. You can either return the toilet, replace the flapper, or try smearing a little vaseline on the underside of the flapper lip where it contacts the tank bottom. The latter may be all it needs to seal a tiny leak.
Villeroy & botch whirlpool does not work
Can you describe the issue at hand a little more?
- What were you doing when it quit?
- How does it normally turn on/off?
- What do the controls look like to turn the tub on?
Rod
US Parts Center
888-521-6183
