20 Most Recent Black & Decker 18 Volt Cordless Drill Driver W/ Charger Questions & Answers
2answers
How do you know when a black and decker battery's life is over
Normally when it will no longer hold a charge, that is, no matter how long you charge it, the battery goes flat very quickly. This happens sooner with Ni-Cad batteries than with Li-Ion.
9/8/2021 12:58:22 PM • Black & Decker... • Answered on Sep 08, 2021
I can't release the bit from the chuck.
If it is jammed then hold the bit in a vice and try to knock the chuck off with a cold chisel or suitable piece of brass. then you can remove the chuck screw and replace the chuck. You should not be able to see the bearings underneath.
2/10/2013 3:36:30 PM • Black & Decker... • Answered on Feb 10, 2013
I droped my 18 volt cordless B&D on the floor and
if it went to pieces when you dropped it, I'll just bet a manual won't help you, I'm thinking a case of super glue.
6/16/2011 4:28:40 PM • Black & Decker... • Answered on Jun 16, 2011
Nicad battery repair
what is wrong with the battery, if is the battery cells generally home user cannot repair them, if it is the housing some mfr's sell replacement housings, let me know and I will go from there
3/22/2011 12:25:28 PM • Black & Decker... • Answered on Mar 22, 2011
The drill has stopped charging up. No obvious
It may be the charger, but most likely the battery can no longer hold a charge. This may happen if the battery drops below its holding charge. Example, left discharge for a couple months. There is little that can go wrong with a charger unless you start smelling burnt plastic from it.
6/8/2010 4:06:15 AM • Black & Decker... • Answered on Jun 08, 2010
Green light stays on when charging the red light
The battery is dead, and the charger will not not charge it. You need to purchase a new battery.
4/11/2010 4:53:18 PM • Black & Decker... • Answered on Apr 11, 2010
How do replace a chuck on a black-decker cordless
you must open the chuck all the way and the screw is in the back inside the chuck this is a left screw which means its righty loosey and lefty tighty; unlike normal righty tighty and lefty loosey.
3/29/2010 5:34:34 PM • Black & Decker... • Answered on Mar 29, 2010
Bought it as new,turned out parts missing,and in used condition
Good for you---stand up for your consumer rights!
3/6/2010 5:29:53 PM • Black & Decker... • Answered on Mar 06, 2010
Smokes from brushes when trigger is pulled
Time to crack it open and have a look at the brushes at the back of the motor, they may be worn down to nothing or contaminated with something that spilled on the drill.
I would contact the nearest service center and buy some new brushes for they are very inexpensive.
Cheers,
Kevin
1/27/2010 5:08:06 PM • Black & Decker... • Answered on Jan 27, 2010
Charger not charging have 2 new chargers neither 1
You should probably contact Customer Service regarding this. I'd say it's a problem with the batteries rather than the chargers considering this looks like a recent EPC model - 1800 444 224
11/17/2009 11:33:54 AM • Black & Decker... • Answered on Nov 17, 2009
Have a Fire Storm place battery in charger green
if you have one check the battery and charger with a meter. if there both fine check the prong's on the battery and the power tool. if charger is'nt charging check the fuss in the charger.. good luck let me know.
10/16/2009 2:22:58 PM • Black & Decker... • Answered on Oct 16, 2009
New charger for Black&Decker 14.4v cd14c
Check Home-Depot. I bought my charger there
for about $ 30.-. There is also a cute Combination of AM/FM Radio/Charger on the
Market, specifically for 18V Batterypacks.
8/24/2009 3:47:42 AM • Black & Decker... • Answered on Aug 24, 2009
I can't loosen the part where the drill bit goes
Try using a large wrench to turn the chuck. It may loosen enough to release the bit
4/19/2009 12:28:35 AM • Black & Decker... • Answered on Apr 19, 2009
A Need a User's Manual
http://www.blackanddecker.com/CustomerCenter/Default.aspx
4/4/2009 10:02:41 PM • Black & Decker... • Answered on Apr 04, 2009
Can my black & Decker 3/8 drill model No.7143 go in reverse
The motor does not go in reverse.
12/10/2023 8:11:01 AM • Black & Decker... • Answered on Dec 10, 2023
Where can I get a battery for Black & Decker Drill CD 1000?
This will be a suggestion...but for mine I bought two 18650 LiFePo4 cells (3.7V each) and replaced the original NiCd Batteries. It has been working for many years now, since the original batteries expired and stop working in 2002 (I bought the CD 1000 back in 1994!!!!!). You have to use a special charger for the new ones but they stay charged a lot more and the drill has more torque.
8/5/2023 1:54:00 PM • Black & Decker... • Answered on Aug 05, 2023
Black & decker 40 volt battery is put on charger it flashes the green light twice then the red light flashes continueously qwhat could be the problem
hi, have you seen this ? https://support.blackanddecker.com/hc/en-us/articles/360012702998-If-my-battery-is-not-charging-what-can-I-try-#:~:text=If%20your%20battery%20is%20not,charger%20to%20try%20charging%20again. Now i don't think that's the issue , it more likely the cells won't take a charger or the bms electronic board has failed , with those battery packs it can be a electronics problem or a failed cell , One thing you might want to check is the actual connection to the battery pack..i seen a issue here where there is a bad connection , the charger won't charge regards Rob
3/13/2023 3:13:19 PM • Black & Decker... • Answered on Mar 13, 2023
Black & Decker 18 Volt Cordless Drill Driver W/ Charger Logo
25 questions posted
Top Black & Decker Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Drills
Most Popular Question
39 t release bit from chuck
  • Drills
