20 Most Recent Black & Decker MS550GB Mouse 5 Amp Detail Sander /Polisher with 41 Piece Ac Questions & Answers
Here's a copy of the manual instructions...
Detail Sanding
Your tool is equipped with a teardrop base which allows you to use it on large flat surfaces
and tight spots or corners.
The pad tips may wear unevenly, depending on use. The pads are designed to allow you to
interchange and /or rotate the diamond tip.
Fitting Sanding Sheets ( Fig. 2)
• Detach the two diamond-shaped tips from the sanding sheet.
If this doesn't provide enough information, take a look at the pictures in the manual at the following link: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/589307-02,MS550GBMS550GH.pdf
If you still have difficulty getting the base off, write back and let me know specifically what the trouble is and I'll try to help you with it.
• Hold the tool with the sanding base facing upwards.
• Place the sanding sheet onto the sanding base.
The diamond-shaped tip can be reversed and replaced when worn.
• When the front part of the tip is worn, detach it from the sheet, reverse it and press it onto
the sanding base again.
• When the whole tip is worn, remove it from the sanding base and fit a new tip.
Tip of the Sanding Base ( Fig. 3)
When the sanding base tip is worn, it can be reversed or replaced.
• Remove the screw.
• Reverse or replace the worn part.
• Fit and tighten the screw.
Finger Attachment ( Fig. 4)
The finger attachment is used for fine detail sanding.
• Remove the screw.
• Remove the diamond-shaped tip holder from the sanding base.
• Fit the finger attachment onto the sanding base.
Contour Holder Attachment (Fig. 5)
• The contour sanding pieces are for sanding curved surfaces and grooves.
• Remove the screw.
sanding base.
• Fit the contour holder onto the sanding base.
Fitting and Removing a Contour Piece (Fig. 6 & 7)
• Choose the contour sanding piece profile most suitable for your application.
• Place one end of the contour sanding piece into the recess at
the front end of the profile holder.
• Push the other end of the contour sanding piece until it clicks
into place.
To remove the contour sanding piece, push it forward then pull the rear end out of
the profile holder (fig. 7).
Fitting a Sanding Sheet Onto a Contour Sanding Piece (Fig. 8)
• Align the sanding sheet with the contour sanding piece.
• Press the sanding sheet onto the contour sanding piece, making
sure that the sanding sheet follows the shape of the profile.
Black & Decker... | Answered on Mar 24, 2009
https://www.ebay.com/itm/BLACK-DECKER-TYPE-2-STAPLES-14MM-B-D-A5918-BD418-DN418-5-PACKS/323540126977?hash=item4b547e8d01:g:scoAAOSweW5VLsTQ:rk:3:pf:0
Black & Decker... | Answered on Nov 14, 2018
They don't have an instruction manual online at the Black and Decker support site, but if you want a look at the exploded diagram, it's here.
Basically there's a collet nut that gets tightened down to hold the bit in place. You've got to loosen it up and you'll be able to pop bits in and out. You've got to have some way to lock the shaft while you're doing this though.
Most modern routers have a spring loaded shaft lock button. While you're holding it in, start turning the collet. When the shaft gets to the point where there's a little hole for the spring lock, you'll probably hear a little click, and the shaft will be locked so you can loosen the collet. If you take your finger off the shaft lock, it pops right back out again so hold it down while you're loosening and tightening.
If you don't see a shaft lock button, you may have a second hex nut at the base and with two wrenches, you can hold the hex nut and turn the collet loose that way.
If this answer was helpful, please give it a vote. Thanks.
Black & Decker... | Answered on Oct 25, 2018
Thought about what my orbital sander is like, then went to a craft store and bought a large sheet/pad of velcro and cut it to fit the 6" rubber disc pad glued it to the pad and then bought hook and loop sanding discs. And you wondering why I didn't use my orbital sander?? Because I needed to get into tight spaces and the orbital sander is a bit too large for this, plus it's too heavy to use working overhead .
Thanks for your site and for asking if problem still exists. Appreciate it.
"Necessity is the mother of invention" Truer words were never spoken
Els439
Black & Decker... | Answered on Mar 10, 2018
The voltage dip followed by a surge caused it to fail.
Black & Decker... | Answered on Dec 25, 2017
You should be able to find them at your local hardware or Menards store. I worked at a True Value store and we had them there.
Black & Decker... | Answered on Dec 23, 2017
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Black & Decker... | Answered on Dec 31, 2016
its listed as a vintage sander
may have to source used ones ... ebay ?
cant find a user manual online
parts might be discontinued
not showing up on the parts list
Black and Decker Sander Parts
Black & Decker... | Answered on Oct 28, 2016
First I question what's the charger doing for whatever you are charging or is it charging? I would say if the only problem is a hum and all else is OK then don't worry, let it be.
Black & Decker... | Answered on Oct 02, 2016
Black & Decker MS550GB Mouse 5 Amp Detail Sander /Polisher with 41 Piece Ac Logo
1 questions posted
Top Black & Decker Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Paul Carew
john h
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Tools & Hardware - Others
Most Popular Question
cannot remove plate pute other plate
  • Tools & Hardware - Others
