20 Most Recent
Bench Factory-Reconditioned Ryobi 2.1 Amp, 6" Grinder ZRBGH616 Questions & Answers
I have a Buffalo Model B-8 bench grinder and am looking for a wire wheel attachment. This grinder was purchased in 1982. Not finding comparable parts anywhere.
A wire wheel is bought from the same sort of supplier as you would buy a grinding wheel.
The dimensions of the wire wheel should be similar to the grinding wheel it replaces, though the centre hole is usually larger and should be fitted and mounted with the correct size plastic bushes and steel retaining washers.
The guard and the tool rest should not be used with a wire wheel for safety and of course there should be a hook nearby to hang a pair of safety goggles...
Bear in mind, in a commercial environment, local legislation could exist that means only a suitably qualified and registered person is allowed to maintain/adjust a grinder as in the UK and Europe.
Replacement parts for Central Machinery 8" bench grinder item #39798
Depends what parts are needed. Spare parts for something that goes wrong so rarely can be difficult especially if the machine is imported.
Some parts will be fairly universal and so fairly easy to obtain - nuts, flanges, abrasive wheels, bearings, capacitor (if fitted) and possibly even the switch and tool rests.
Replace missing switch on bench grinder
2 wires are not needed to use they are the wires of an supression capacitor on the switch then there are 2 wires from your power cable and 2 that goes to your motor that 4 you only you have to use you can also connect the 2 wires from the s-capacitor with te wires on the motor together thats is how its also correct, (but best is to remove it because its only for suppression for FM ukw radio signals and everybody has DAB+ and the change to have short-circuit is reduced.
What is motor starting capacitor of GB800 Bench grinder
Hard to find the data The tool is having an centrifugal switch to an breakercontact on the armature on the startup-winding where the capacitor is on , so it should be oft a high capacitance try it to start with 20 mf is maybe high enough to start. you can possible go to less with the capacitance . size compare of the capacity range is difficult because the last years the size differs much and are less
