20 Most Recent
Hammer Set Of 4 Hilti Concrete Drill Bits Sds Plus Questions & Answers
My te-72 will hammer but not drill. Any suggestions?
The TE-72 rotary hammer drill is designed to perform both drilling and hammering functions, so if it's not drilling, there could be a few potential causes:
- Dull or damaged bit: Check the bit to make sure that it is sharp and not damaged. A dull or damaged bit may not be able to penetrate the material you're trying to drill through. If the bit is dull or damaged, replace it with a new one.
- Incorrect bit size: Make sure that you are using the correct bit size for the material you are drilling through. Using a bit that is too small or too large can cause the drill to spin without making any progress.
- Worn chuck or collet: If the chuck or collet that holds the bit in place is worn or damaged, it may not be able to grip the bit properly, which could cause the drill to spin without making any progress. Inspect the chuck or collet and replace it if necessary.
- Low power or voltage: If the drill is not receiving sufficient power or voltage, it may not be able to drill through the material. Check the power cord and outlet to ensure that they are functioning properly.
- Malfunctioning clutch: The clutch in the TE-72 rotary hammer drill is designed to disengage the drill from the material in case of a jam or overload. If the clutch is malfunctioning, it could cause the drill to stop drilling. Have a professional technician inspect and repair any faulty components.
If none of these solutions work, it's recommended to take your TE-72 rotary hammer drill to a professional repair service for further diagnosis and repair.
How do you install brushes on a 5370 hammer drill
If they are replaceable, you will be opening up the drill by removing the screws holding it together, and then you might see the brushes that need replacement.
Know that although you can open most hammer drills, and you can replace the brushes in some, some you cannot reassemble, but you can surely try.
I fix these myself, and my success rate is about 50 %.
God bless your efforts.
TE 12 the hammer not work
With hammer drills, there are usually 3 positions for operation.
Position 1 - Drill only - drill rotates
Position 2 - Hammer and Drill - Drill rotates and hammers
Position 3 - Hammer only - hammer action
It is important to read the instructions to activate the part to select position 1, 2 or 3.
Sometimes, it is easy to move from position 1 to position 2. Sometimes it is easy to move from position 2 to position 3.
Sometimes it is difficult to move from position 2 to position 3.
When it is difficult to move from position 2 to position 3, you may need to rotate the chuck a little way before turning it to position 3.
Can anyone supplier me with name of supplier or can provide me with chuck gearing for my jcb 24 v [new style] cordless hammer drill
If you are looking to change the keyless chuck to a keyed one, give it up. I cannot get the keyless chuck off my drill and I suspect it has permanent set loctite which would require heating the shaft and chuck. Disassembly would be required to apply enough heat to break the bond. For me I cannot justify time and trouble to disassemble and reassemble the gearbox on the drill. I have found hex or triangular drill bits, hole saws, and countersink tools that will not slip in a keyless chuck but... I still do not like those darn things.
