20 Most Recent
Milwaukee 0612-20 14.4v Cordless Drill Kit W/ Worklight Questions & Answers
How to unlock the chuck
this how to get a chuck off a drill.look inside the chuck for a screw. it will be a left handed screw.once
you get the screw out put the chuck in a vice . you will need to
squeeze it very tight. then put the drill in reverse and pull the
trigger.if i wont come off you will need to hit the chuck with a hammer
while you are holding the trigger. if you have a bit stuck in the chuck and cant get it out put the chuck in the vice and hit it very hard with a hammer until the chuck falls apart.i work on drills every day ,this is the only way we have found that works
7/23/2017 8:12:22 PM •
Milwaukee...
Answered
on Jul 23, 2017
The drill gun does not
The reversing lever(13) may have popped out of the reversing lever on the switch, but more likely the switch is bad:
The Switch part number is 23-66-0690 and costs about 25.00
The tool will have to be taken apart to verify this, and if it is under warranty, you will want to have the service center do it. Just type your zip code into this link, and it will find the nearest service center that can work on it, or just sell you the part.
http://www.milwaukeetool.com/parts-service/find-service-center
11/30/2010 10:11:36 PM •
Milwaukee...
Answered
on Nov 30, 2010
How do I take out the spindle on a 1675-1 Milwaukee hole hawk drill
To remove the spindle on a Milwaukee Hole Hawg 1675-1 drill, you will need to follow these steps:
- Disconnect the drill from the power source and remove the chuck key.
- Turn the drill over so that the chuck is facing upwards.
- Locate the spindle lock button on the side of the chuck.
- Press the spindle lock button and hold it down while rotating the chuck counterclockwise to loosen it.
- Once the chuck is loosened, you can remove it from the spindle by pulling it off.
- To remove the spindle from the drill, you will need to loosen and remove the retaining bolt that holds it in place. The retaining bolt is typically located on the bottom of the drill, near the front of the spindle.
- Once the retaining bolt is removed, you should be able to lift the spindle out of the drill.
It is important to follow these steps carefully to avoid damaging the spindle or the drill. If you are having difficulty removing the spindle, you may need to consult the owner's manual or a certified mechanic for assistance. They will have the necessary tools and expertise to help you remove the spindle safely.
How to clean M18 milwaukee impact
Tec7gt7 ( recommend spray ) electrical safe for switch and motor commutator. for novice and expert. do not use wd40.
Use if very dirth A cold degreaser for only cleaning the 2 housing parts
