20 Most Recent
Black & Decker BD12PSK 12-Volt Smart Select Drill Questions & Answers
The rod holding the chuck
You don't need that screw that fell out if you can't get it back in the chuck is threaded on and you probably will never have a problem with it again. Good Luck...
Bit is stuck / jammed. Can't seem to loosen. Any
If the chuck is too tight to get the bit out you can either put a glove on one hand grab the chuck and run the drill in the reverse direction or if that will not work use vise grips or a small pipe wrench on the chuck to loosen it but be sure to tape the pipe wrench or vise grips with a thin piece of duct tape so you don't gouge the drill chuck.
When do i know when the battery is chagered
On most chargers the light will flash when it is charging and stop flashing when it is fully charged. It may also have 2 lights that indicate when it is charged. Or it may have a yellow light that turns green when it is charged.
Where can I get a battery for Black & Decker Drill CD 1000?
This will be a suggestion...but for mine I bought two 18650 LiFePo4 cells (3.7V each) and replaced the original NiCd Batteries. It has been working for many years now, since the original batteries expired and stop working in 2002 (I bought the CD 1000 back in 1994!!!!!). You have to use a special charger for the new ones but they stay charged a lot more and the drill has more torque.
How to remove a chuck from Black & Decker VPX1212 drill
Open the chuck as wide as it will open and look inside to see what type of screw/bolt it uses then using the correct tool insert it into the chuck and undo the bolt/screw, usually it will have a left hand thread so to unscrew it needs to be rotated in a clockwise directions, hold the chuck tightly but dont use excessive force if this does not work then try unscrewing it in the opposite direction, at all times be firm but like I mentioned earlier dont use excessive force.
