20 Most Recent
IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR KIT-Air Brush Questions & Answers
I am using an iwata
Air brushes us a Theory called a "venturi" in where air pressure lowers the pressure where the paint is kept and causes it to go out the nozzle. I would try seeing if there is an obstruction in the hoses to the brush and confirm that the compressor is moving air. If none of these things are an issue also while cleaning the parts may give the appearance that the item is clean then try soaking them over night in paint thinner and replacing the O-rings and gaskets.
4/27/2011 6:05:52 PM •
IWATA -CS...
Answered
on Apr 27, 2011
Air compressor regulator
hi my iwata powerjet lite shut down.theres power but no performance.it only gets used for prob ten hours a week,somtimes weeks without use.is this common and expansive to repair.thank you.re ****.
2/21/2011 8:49:26 AM •
IWATA -CS...
Answered
on Feb 21, 2011
I have some severe free flow goin on, on my hpbcs iwata eclipse
It sounds like you have a problem with the air valve. Possible deterioration of the valve material? I am not sure what they use, but if it is a rubber the cleaning thinner MAY have destroyed its properties if the cleaner got into the air path and valve.
2/18/2010 2:04:43 PM •
IWATA -CS...
Answered
on Feb 18, 2010
Bubbles in color cup of airbrush
I assume you have adjusted the nozzle... On my unit, there is a SMALL hole in the cap for the cups to let in air above the paint. Also OFTEN the paint must be thinned to use in an airbrush. Since you havent been able to draw water even, thinning is NOT the problem.
The airbrush aspirates the paint by Bernouli's principle, that is where there is higher velocity of a fluid, there is a lower pressure. The nozzle creates that and the adjustment is important. On mine which is a "Wren", I think by Binks there is a conical piece that the paint comes out of with a throttling needle. This has the be unscrewed to open the paint path and adjust it. The air flows at high speed around this cone creating a vacuum.
The headline says "Eclipse" but that is a gravity feed so I suspect that is the old Fixya problem of having incomplete choices to pick from.
2/18/2010 2:01:36 PM •
IWATA -CS...
Answered
on Feb 18, 2010
I need a head valve seat for central pneumatic 21 degree angle framing nailer model 60828 also need headvalve seat for 34 degree angle finish nailer 68020
I have not been able to purchase replacement parts for these nail guns , however, have repaired them using parts from Bostitch framers and or just make the part. If the seal fits over the top of the cylinder, then try using seal from Bostitch framer part #N70155 fits a bit tight but works. Heat with a hair dryer to soften and install. If the seat is incorporated within the head valve, just dig it out and replace it with liquid two part urethane. Just mix and pour it in. After cleaning out the old seal, place head valve on level surface and pour in the mixed urethane till slightly over full to give the seal a nice crown. The finish nailer might also be repaired using other brand of seals. Remove the old part and take it to service center for a possible match. Good luck with your repair.
What oil should I use in Handiair H8/25 Compressor?
Many air compressors use a mineral blend or a synthetic oil, such as synthetic hydrocarbon, polyol ester or polyglycol. It is important to use a lubricant specifically rated for air compressors; do not use a general-purpose motor oil used for automotive or other purposes.
Read your user manual for more information.
