20 Most Recent
Uniden TRU 448-2 Cordless Phone Questions & Answers
Uniden tru448-2 rotary dial
You can download the manual from the link below:
http://www.uniden.com/pdf/TRU448-2om.pdf
To set tone dialing see picture below:
Please update the question & let us know if the information given was useful to you - Good Luck!
Uniden TRU 448-2
Here's the link;
http://www.amazon.com/Uniden-TRU-448-2-Cordless-Digital-Answering/dp/B000063KDW
under "product details".
Hope this helps :)
Second hand set doesn't work
The second hand set problem was resolved by placing it face down on the base unit. Apparently it needed to be reset for some quirky reason.
I found the solution in the manual, and although it didn't really address the problem, I thought it was worth a try. It worked.
Can I add another uniden hand set to a uniden D1680 series
The Uniden D-1680 system can have up to 12 handsets registered to the base. (The phone system was sold in bundles with 0 to 11 accessory handsets.) However, this cordless phone system has been discontinued. I can only find used DCX160 handsets (the compatible accessory handset) on Amazon and E-bay.
I hope this helps.
Sync 2 versions of Uniden Dect 6.0 to work off the same base.
Yes, you can join an older and a newer version of Uniden Dect 6.0 cordless phones to work off the same base. Here are the steps to sync them:
- Disconnect the power cord from the base of both phones.
- Take the battery out of each handset.
- Wait for a few minutes.
- Reconnect the power cord to the base of the newer version phone and insert its battery.
- Wait for the phone to register on the base, which should take a few seconds.
- Once the newer phone has registered, repeat steps 4 and 5 with the older version phone.
- The older version phone should now register on the same base.
- Test the phones to make sure they are working properly.
If for some reason the phones do not register on the same base, refer to the instruction manual that came with the newer version phone for further troubleshooting steps.
A uniden phone DECT 6.0. how do i turn on call waiting
Talk to your telephone service provider. There will be a fee.
(Uniden landline phones can make or receive calls; some models have a answering system. Most current models can even check if you have messages on the telephone provider's voice mail. (Sometimes, they'll give spurious voice mail information.) However, they don't have any built-in way of seeing any data (another call) from the telephone provider when the phone is in use.)
