20 Most Recent
RTO Lifestyler Expanse 8.0 Treadmill Walking Belt Questions & Answers
The walking belt on this Lifestyler Expanse 8.0
I'm sorry to say that the belt is toast and needs to be replaced. I would also check the end caps I believed it is a one piece unit that the belt
tension bolt is attached and the left side had cracked and cause this problem. Call Icon Fitness @ 1-800-999-3756 with locating the proper parts and pricing
Treadmill stuck on run - will not change speeds
Fist off your treademill old and most likely they no longer make the parts. This was a unit sold at sears a longtime ago. Your buttons could be stuck at the top head board. you have to peel cak the membrane to un stick them. If not , then the lower board has blown. No repair for this. no replacement as well. you may to get a new treadmill. You may be able to do one more thing to work around the problem. I need to be paid someting to assist with that. I’m happy to help further over the phone at
https://www.6ya.com/expert/howard_079189dd4959a511
We just bought a gently
From the manual: Troubleshooting
Symptom: The walking belt slows when walked on
a. If an extension cord is needed, use only a 14-gauge general purpose cord of five feet or less in length.
b. If the walking belt is over-tightened, the treadmill performance may decrease and the walking belt may be permanently damaged. Remove the safety key and UNPLUG the power cord. Using the 3/16" allen wrench, turn both rear roller adjustment bolts counterclockwise. 1/4 of a turn. When the walking belt is properly tightened, you should be able to lift each side of the walking belt 3-4 inches off the walking platform. The center of the walking belt should just touch the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert safety key and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
c. If problem persists, contact customer service.
