20 Most Recent
WEIDERFITNESS.COM Weider Platinum Plus Questions & Answers
My friend gave me her
You may have to take it apart one section at a time take photos of this project unless IconFitness has a manual for this unit. I suggest this course of action check , clean and if needed lubricate all movable parts then reassemble unit. If you want to put in the time.
I just got a weider platinum off someone but there
I have the Chart Poster and manual
Poster:
print:
http://www.zazzle.com/weider_platinum_excercise_chart_poster-228106828410296215
Download:
http://www.mediafire.com/?5dzm31drljz
The manual I have to email you as every place i've found tou get it you have to pay for.
I HAVE ASSEMBLED MY 4250
hi,
can u please tell me which kind of help do u need means regarding installation or operation etc..
Thanks!
Sandy
Weider Platinum Crossbow is locked up.
i have the manual, to recalibrate the machine press and hold the next button and the motorized wieght adjustment+ button for five seconds. when the buttons are released, a number will appear in the reps display. press the next button again, then press the motorized weight adjustment+ button: this should start the reclaibration process. i am lucky i bought the machine in 10-2004 and it has a ten year warrenty. it isn't working it happened before and they had to replace the motor. if it works remembe to unplug the machine when not in use. it is a great machine to get in shape with. you just have to use it.
I just bought a used machine and the weight
If you find the manual (quick online search) on page 23 there is a section under "RECALIBRATE THE MACHINE" . Basically: Plug it in. Hold down the "Next" and "Resistance +" buttons together for 5+ seconds and release; some text will appear on the main display. Press "Next" again followed by pressing the "Resistance +" button again. The system should 'calibrate', you'll hear it moving thru the resistance lowest to highest (or vice versa). After it finishes it beeps or displays or both, unplug the system. When you plug it back up hopefully it fixes the problem.
