20 Most Recent Uniden DCT648-3 Cordless Phone Questions & Answers
Phone rings once and then goes beep,beep,beep
I means the paygo phone you are calling is out of funds.
12/27/2014 8:13:57 PM • Uniden DCT648-3... • Answered on Dec 27, 2014
DCT648-3 uniden phone won't stop blinking, though fully charged, and no messages
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
7/9/2014 8:00:30 PM • Uniden DCT648-3... • Answered on Jul 09, 2014
5answers
Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
10/16/2013 12:21:07 AM • Uniden DCT648-3... • Answered on Oct 16, 2013
Checking voice mail remotely
This may be a little late, you are probably home already, but here it is anyhow:
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a remote
location (when you are away from home, or from another room using a handset).
Additionally, you can turn On or Off your answering system remotely.
Remote access away from home
You can operate your answering system from a remote location using any
touch-tone telephone.
1) Call your telephone number and wait for the system to answer. If the answering system is
off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off),
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" on page 25
or 54).
3) The answering system announces the current time and the number of messages stored in
memory. You hear "To play incoming messages, press zero-two. For help, press one-zero".
You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered within 2
seconds. You may select a command from the following chart:
Command Function Command Function
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help Guidance
* For Repeat a Message function, press 0 then 1 within about four seconds to repeat
the previous message, or press 0 then 1 after about four seconds to repeat the
current message.
** For Memo Record and Greeting Message Record function, the first time you enter the
corresponding command, it starts the Recording function. If you want to stop the
recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the system
is in the command waiting mode. You may enter another command at this time from the
chart above.
6) When you are finished, hang up to exit the system. The answering system automatically
returns to standby.
7/25/2013 5:38:22 PM • Uniden DCT648-3... • Answered on Jul 25, 2013
I have verizon phoneadr6350 and i have tmobil service how can i use my simcard
i lock my samsung galaxy pockethow can i unlucking
1/25/2013 10:35:08 PM • Uniden DCT648-3... • Answered on Jan 25, 2013
I need an owners manual
Here you go
http://www.uniden.com/pdf/DCT648om.pdf
Enjoy!
3/3/2011 4:17:16 PM • Uniden DCT648-3... • Answered on Mar 03, 2011
3answers
Handset not working
I had this exact problem. My solution was to clean the top of the condensor microphone. Something was spilled onto the phone and ran down into the hole that leads to the microphone. It not only affected the microphone, but made some of the buttons stick as well. The phone is not difficult to disassemble, just try not to touch the electronic components. If you are experienced in electronics, you may know that using a wrist strap( available at electronics supply stores or online) and grounding yourself will help protect the electronics. While you are at it, get some pure isoproply alcohol, and some cotton swabs, making sure that the swab is saturated with the alcohol. Just clean around the interior area of the phone where the condensor microphone is. You will want to even remove the black screen over the microphone to be sure everything is clean!!! Make sure the little hole that leads from the front of the phone to the microphone is clear and clean. I believe you will solve your problem.
1/2/2010 11:14:04 AM • Uniden DCT648-3... • Answered on Jan 02, 2010
Base station has a display of E1
base station has a display E 1 and no dial tone
10/9/2009 6:32:16 AM • Uniden DCT648-3... • Answered on Oct 09, 2009
My uniden dct648GHZ phone has the same error
THAT IS AN ERROR MESSAGE, PHONES NEED TO BE REPLACED.
9/7/2009 5:12:03 AM • Uniden DCT648-3... • Answered on Sep 07, 2009
IT RINGS BUT YOU CAN NOT ANSWER THE PHONE EXECT FROM THE BASE
See if in the menu choices there is an option to reset all factory defauts. It seems someone has mistakenly locked out the other to units. Can you still use them as intercoms?
8/13/2009 9:02:13 PM • Uniden DCT648-3... • Answered on Aug 13, 2009
My uniden dct648-3 keeps saying "warning please wait" and it fully charged - so it says. i can hear the phone ring but as soon as i pick it up and hit talk, that darn message appears and i hear nothin
I had this exact same problem. I had to reset all three handsets. Select menu, system reset, replacing base, then follow directions. This worked for one unit but the other ones I had to buy new batteries eventhough they showed fully charged. Good Luck
7/1/2009 3:48:39 AM • Uniden DCT648-3... • Answered on Jul 01, 2009
Uniden DCT648-3 Cordless Phone Logo
51 questions posted
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Uniden Lands Phones
  • Uniden Lands Phones
Most Popular Question
handset not working
  • Lands Phones
