20 Most Recent Uniden Oceanus DSC Wham ready Fixed Mount VHF 2-Way Radio Questions & Answers
2answers
Uniden Oceanus not transmitting
You may have a sub-channel/privacy channel activated. Unless the person/s you are trying to talk to have the same channel and code set they will not be able to hear you. Check your manual for specific instructions on how to reset it to the default.
3/10/2016 10:52:02 PM • Uniden Oceanus... • Answered on Mar 10, 2016
I need uniden oceanus installation maual.
From the Oceanus owners manual (page 8, link below) it tells you how to choose a mounting location and complete your install. -Steve http://www.uniden.com/pdf/OCEANUS%20DSCom.pdf
3/31/2015 1:13:44 PM • Uniden Oceanus... • Answered on Mar 31, 2015
How do replace the face plate/mic assembly on uniden oceanus dsc
I realize this question has been around for a long while, but with the price of a new radio being so low, I can't imagine why anyone would be bothered with trying to source the part (spendy...) and try to repair the unit. Welcome to the age of disposable electronics. -Steve
3/31/2015 1:01:12 PM • Uniden Oceanus... • Answered on Mar 31, 2015
How to operate the MD 200R
user manual downloadhttp://www.manualowl.com/p/Motorola/MD200R/Manual/173752best regards Falco
11/4/2013 10:22:37 PM • Uniden Oceanus... • Answered on Nov 04, 2013
Where do I find or
The antenna is not listed as an accessory on the Uniden web site, so your best bet is to contact their Customer Service department. You can email them by following this link:
http://www.mycusthelp.net/uniden/_cs/QuestionAsk.aspx
Bill B.
11/7/2010 2:45:12 PM • Uniden Oceanus... • Answered on Nov 07, 2010
2answers
My manual is not in english
try this link and good luck.........
http://www.retrevo.com/samples/Uniden-manuals.html?cmpid=Manuals_Uniden&s_kwcid=uniden%20manual|4347054231&adsense=2257534859&gclid=CNib_Ii476ACFUpf2godCksrcw
8/21/2010 11:37:31 AM • Uniden Oceanus... • Answered on Aug 21, 2010
Uniden VHF Marine DSC Series 25 Watt Radio
Typically there is an inline fuse in the power cord. It is not built into the back of the unit. If access to the back is restricted, they should have cut out the fuse and installed it near the power buss that the power cord is attached to. How was it flush mounted if you don't have access to the back of the unit? It's not possible to attach the flush mount brackets without access. It's possible that the radio is held in place using sealant. If you are sure there's no way to pull the panel, try gently prying the radio out of the hole working around the edge to break the seal.
5/10/2008 2:40:11 AM • Uniden Oceanus... • Answered on May 10, 2008
Uniden vhf
Initially, pls check/clean your antenna, mount, coaxial cable, RF connector, power leads, grounding straps.
Based on your post description, a couple of ideas:
1. Since you receive OK, chances are the antenna/cable is good. You verify though with an SWR meter;
2. Since TX light comes on, looks like the mic, PTT and coiled cord are all OK;
3. All else works but no one can hear you, you have no power output. Use an RF wattmeter with dummy load to verify that you are pushing at least 25 watts. In the absence of a power meter, the SWR would also do or even an indication of a significant current flow to the radio ( use an inline ammeter) would indicate power.
As you will note, some specialized instruments are needed. Perhaps your best bet would be to seek the services of a qualified communications technician. TMore often it is the finals or power pack that fails resulting in no TX. In some cases, it is either the RF diode or the power regulator that causes no TX. It may also be worth your while to do a full check over of your antenna system.
Hope this be of some help. Pls post back how things turns up or should you need additional information.
Good luck and kind regards.
1/2/2008 10:31:44 PM • Uniden Oceanus... • Answered on Jan 02, 2008
3answers
Need free codes for a base police scanner
hello there
please try these links they have worked for me
  1. Scanner Frequencies & Codes Free Trunked Fleet ID's for your area (Works with Scancat) Military Base Operations Frequencies ... Get a scanner frequency list by email for your county, ...www.bearcat1.com/free.htm - Cached
  2. Portland Police Scanner | Portland, Oregon Crime & Emergency Dispatcher ... ... use of a Trunk Tracking Scanner and entering the Talkgroup codes listed in the next section. ... your Business Listing for free. Obits / Death Notices ...oregonlive.com/policescanner/...?/policescanner/police_codes.frame - 64k - Cached
  3. Scanner Feeds ... Feeds Police Codes Police 11 Codes General Codes General Acronyms ... They are free. ... Big Bear, California Police Scanner (web-based) Los Angeles Police ...members.shaw.ca/crazykid755/scanner - Cached
2/7/2024 2:07:07 PM • Uniden Radio... • Answered on Feb 07, 2024
Owners manual Uniden Bearcat BC590XLT
The Owner Manual is here Noel
Bearcat BC-890XLT Scanner owner's Manual
repeater-builder.com https://www.repeater-builder.com > uniden > pdf PDF Please read this Operating Guide thoroughly before operating the scanner. Optional Accessories. The following optional accessories for your BC 890XLT are ... 40 pages ..
6/24/2023 5:09:47 PM • Uniden Radio... • Answered on Jun 24, 2023
Uniden Bearcat BC 220XLT Radio Scanner repair/service manual
Some help here, but what you want to be likely not possible. https://www.google.com/search?q=Uniden+Bearcat+BC+220XLT+service+manual ..
5/23/2023 2:41:51 AM • Uniden Radio... • Answered on May 23, 2023
I need a battery for UBC3000 please?
All questions need full 'make model (what it is)' or we guess. I see a number of UBC3000.
Uniden - UBC3000XLT Battery
Complete Battery Source https://www.completebatterysource.com > uniden-ubc... The Uniden - UBC3000XLT Nickel Metal Hydride (NIMH) battery is the perfect replacement battery at a great price! The Uniden - UBC3000XLT battery is ... Capacity: 1100 Length inches: 2.7 US$43.55
3/10/2023 11:22:58 PM • Uniden Radio... • Answered on Mar 10, 2023
D104-M6B WIRING FOR A UNIDEN 880 RADIO DIGRAM
Here is the wiring diagram for connecting a D104-M6B microphone to a Uniden 880 radio:
  • Shield: Connect to pin 1 of the microphone jack on the radio
  • White: Connect to pin 2 of the microphone jack on the radio
  • Red: Connect to pin 3 of the microphone jack on the radio
  • Black: Connect to pin 4 of the microphone jack on the radio
It's important to note that not all Uniden 880 radios are wired the same way. If you're unsure about the wiring on your specific radio, it's best to consult the manual or contact Uniden customer support for assistance.
2/26/2023 4:12:25 AM • Uniden Radio... • Answered on Feb 26, 2023
Uniden UBC370XLT Scanner. Hello, I am looking for a schematic diagram for a UBC370XLT. Does anyone have a copy or know where I might be able to get one please?
Question edited for clarity and add maker + (what it is). Question moved from Misc. You will have to contact Uniden direct. This search query should find it. The CLT model seems better known https://www.google.com/search?q=UBC370XLT+schematic More here including software https://www.google.com/search?q=%22UBC370XLT%22 ..
1/5/2023 2:36:14 AM • Uniden Radio... • Answered on Jan 05, 2023
Uniden 210 XLT. What modification to pick cell phone frequencies
Question edited into english. No modifications. The range is restricted and the calls are encrypted.
12/1/2022 4:28:40 AM • Uniden Radio... • Answered on Dec 01, 2022
How to wire a Superstar 507-5 microphone to a Uniden Washington base unit please?
It should just connect with the plug eBay states. This is a brand new Workman replacement omni-directional CB radio microphone. Features a 5-pin connector and a flexible coiled cord. Wiring:
  • Pin 1 - Audio
  • Pin 2 - Ground
  • Pin 3 - RX
  • Pin 4 - Common
  • Pin 5 - TX
  • Compatible Radios:
  • Cobra 90LTD
  • Cobra 140GTL
  • Cobra 142GTL
  • Cobra 148GTL
  • Cobra 148-F-GTL
  • Cobra 2000GTL
  • Cobra 2010
  • Uniden Washington
  • Uniden Grant XL
  • Uniden Madison
  • https://www.google.com/search?q=connect+Superstar+507-5+microphone+to+a+Uniden+Washington ..
    11/27/2022 9:08:36 PM • Uniden Radio... • Answered on Nov 27, 2022
    I have an Old Uniden BC760XLT scanner been sitting for months..now it Appears by the display To be Scanning,No Audio I've tried the internal/external speaker/recorder jack ..No Audio..any ideas?
    Probably has some leaky capacitors that stop it from working and just shows a display without tuning at all.
    7/6/2022 5:49:23 AM • Uniden Radio... • Answered on Jul 06, 2022
    I just received a Uniden Bearcat handheld scanner model BCD325P2.
    all it can do is in the manual. 2015 made new. all those safety channels frequencies are regulator by FCC.gov and are published here they are, first google hit ,amazing. https://www.radioreference.com/db/browse/stid/12 keep in mind some 800MHz transmitters (gov) are encrypted trunking mode radios, (like police is) in my town text, the HAM band 2meters has full time weather brocast (I have HT and HF here) our RAD does 25mHZ to 900mHz bands all stated in the manual below. page 129 covers the public service bands starting at 758.0125 MH vhf and uhv is line if site comms so that is why there are so many stations. (broad casting) best is try the closet one first. a better antenna , is what to use. what kinds of safety data do you need, not told fire, police , amber alerts, weather, road reports, and lots more what you want not told. but you can find it if you google that, in clear simple text. for sure. by county is best. as it is line of site. police bands are trunked and have are networked sites to overcome line of site issues,. (magic) and is encrypted.(and ******* to hack btw) broadcast is site by site and 20 miles max (aprox) but station power in watts is prime there, and no 2 stations are the same, (rare) set the radio to scan them all , see what it finds.? be patient. or look up what you want googled. https://www.manualslib.com/manual/952528/Uniden-Bcd325p2.html?page=129#manual good luck and happy DX'ing.
    7/2/2022 3:06:23 PM • Uniden Radio... • Answered on Jul 02, 2022
    How to setup a uniden BC75XLT BEARCAT?
    https://www.roadtrucker.com/images/manuals/uniden-bc75xlt-user-manual.pdf
    6/12/2022 11:17:03 PM • Uniden Radio... • Answered on Jun 12, 2022
    Uniden Oceanus DSC Wham ready Fixed Mount VHF 2-Way Radio Logo
    Popular Tags
    9 questions posted
    Top Uniden Radio Communications Experts
    John
    John
    eradiostore
    eradiostore
    Grand Canyon Tech
    Grand Canyon Tech
    Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
    View Most Popular
    • Uniden Radio Communications
    Most Popular Question
    uniden vhf marine dsc series 25 watt
    • Radio Communications
