The Warbeast is notorious for having buzz problems, and the major cause is usually the bridge. What you can do is:
Standard B.C. Rich String-through bridge - There are two posts, one on either side, that are slotted for a flat-head screwdriver. It is NOT recommended that you try to adjust this with strings on the guitar! Turn the posts counter-clockwise to raise the bridge height. Be sure to turn them the same amount, to keep the string height in relation to each other the same.
Floyd Rose Licensed Tremolo - You will have to adjust the springs behind the tremolo to bring the bridge up slightly above level. You have to have the strings on the guitar to do this To do this, remove the spring cover on the back of the guitar. A phillips-head screwdriver is needed. There should be two screws, one at each end of the spring keeper. Turn them counter clockwise by 1/4 turn each time, following these steps:
1. Turn a single 1/4 turn
2. Tune the guitar.
3. Check for buzz.
If the buzz is still present, repeat steps 1 - 3.
I could not find any other bridge that came with this guitar, so one of these two options should help. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/cameron_463100ffd54b591d
