20 Most Recent Epiphone Elitist Country Deluxe Hollow Body Electric Guitar Questions & Answers
Make you a hook out of a coat hanger. Get inside and hook the wiring to the jack, take the nut off the jack and pull it up through the F hole. You can plug in to it a patch cord so you can pull it back through once fixed. Check out Guitarelectronics.com for a wiring diagram.
Epiphone Elitist... | Answered on Sep 25, 2011
Korea, 1996, July as best as I can make out from https://forum.gibson.com/topic/139846-epiphone-serial-number-decoding/
without knowing the model and the condition, there's no telling what it's value is. Check reverb.com for similar guitars
safe to say tho that a Korean made Epiphone is not a classic (pre-Gibson) and will not be a high value guitar.
Epiphone Music | Answered on Nov 02, 2019
Sounds like perhaps a Les Paul Special II, but more detail is needed to say for sure. There was a lot of variation in their Les Paul models. Posting a photo of both sides and the headstock is best.
-Has the guitar any binding, and what colour?
-Is the back of the guitar white or all black?
-Exactly what is on the front of the headstock, 'Epiphone', the 4-diamond logo, anything else?
Epiphone Music | Answered on Sep 11, 2019
The controls should be setup in pairs (as long as the electronics haven't been modified. The two closest to the pickups are the volumes and the other two are the tone controls. The top knob set should be your neck pickup and the bottom set is for the bridge.
Schematics and wiring diagram for the typical les paul (sheraton) controls:
http://www.guitarelectronics.com/product/WDUHH3T2202
Approx 1965. Cant determine value without model #
Epiphone Music | Answered on Aug 21, 2019
Possible manual from manufacturer web site found using https://www.google.com
May be a different model than yours.
http://images.epiphone.com.s3.amazonaws.com/Media/Manuals/EpiOwnrsManul.pdf
Epiphone Music | Answered on Aug 13, 2019
Request the wiring diagram directly from Epiphone.
Epiphone Music | Answered on Jul 10, 2019
The Epiphone serial number decoder, I use, supports 12 serial number formats from 25 factories. Vintage numbers from 1932 to 1970 are supported. Serial numbers from 70' and 80's era Epiphone guitars made in Japan are not supported. The reason for this is that there is no reliable documentation from this time period. This Module has been updated to work with the newer serial number formats. Looks like your Epiphone is Japanese. Try a guitar dealership or contact Epiphone for advice.
Epiphone Music | Answered on Jan 29, 2019
Epiphone - The Guitar Dater Project - Epiphone Serial Number Decoder
https://www.guitardaterproject.org/epiphone.aspx
The Epiphone serial number decoder currently supports 12 serial number formats from 25 factories. Vintage numbers from 1932 to 1970 are supported. Serial ...
Epiphone Serial Number Decoding - Gibson Brands Forums
forum.gibson.com > Gibson Brands > Epiphone > Epiphone Acoustics
Oct 30, 2017 - 5 posts - ‎4 authors
This serial number formats is solely used on Epiphone Elite or Elitist models. ... F-Serial Numbers onLes Paul Standard '59/'60 Models and ... Epiphone Les Paul Standard with TWO serial numbers?!?!
Dec. 11, 2011
Epiphone Les Paul Serial Number
Feb. 14, 2010
Look up your Epiphone Serial Number
Oct. 27, 2009
i.d. your Epiphone here -- serial # key, guitardater link + ...
Feb. 15, 2009
More results from forum.gibson.com
Gibson And Epiphone Guitars Serial Number Guide ' The Music Zoo
https://www.themusiczoo.com/blogs/.../gibson-and-epiphone-guitars-serial-number-gu...
May 4, 2011 - Les Paul Classic: This model features an ink stamped serial number with no "MADE IN USA" (just as we used on the original 1952-1960 Les Pauls). Most will be 5 to 6 digits in length, but the earliest examples feature 4 digit serial numbers.
Epiphone serial-number-information - identification ' Epiphone Guitars
www.epiphonetalk.com > Forums > The Guitar > Epiphone Guitars
Aug 11, 2017 - For Epiphone serial numbers that begin with a letter(s), this list ... F - Qingdao (China) = Les Paul Standard '59 / '60 / Tribute Models (See: ...
epiphone les paul standard serial number Google Search
Epiphone Music | Answered on Nov 26, 2018
That serial number was used more than once.
If it has 'Made in USA' on the headstock, it was made at the Bozeman Plant, MT, USA on July 21st, 2000.
Otherwise it was made in Korea in March, 2002.
Epiphone Music | Answered on Mar 31, 2018
That guitar was made in Korea in August, 2004
Epiphone Music | Answered on Jan 25, 2018
We don't do that here, check with them...
Epiphone Music | Answered on Dec 15, 2017
Your guitar was made at the Qingdao Plant (Epiphone), China in April, 2016
Epiphone Music | Answered on Nov 27, 2017
Does this guitar have a esonic 2 system, if so the other pickup is piezo pickup located under the saddle, there should be two wires coming from the pre-amp just remove the pre-amp from the body and make sure that the two wires are still plugged in and attached to the pickups, these are plugs like a small headphone style plug, just check these and the wires are held in by small wire clips,one of the wires may have came out of the clips...hope this helps I will look for a schematic for you and post it if I find one...Good Luck!!!
Epiphone Music | Answered on Nov 18, 2017
Epiphone Elitist Country Deluxe Hollow Body Electric Guitar  Logo
1 questions posted
Top Epiphone Music Experts
Michial Gueffroy
Cameron Lewis
Cameron Lewis
Level 1 Expert
rhodesworks
Are you an Epiphone Music Expert? Answer questions, earn points and help others
View Most Popular
Epiphone Music
  • Epiphone Music
Most Popular Question
epiphone dot just started
  • Music
