20 Most Recent
Roland JUNO-D Synthesizer Questions & Answers
On my Roland E16 the slide volume control is out
Before replacing TRY flushing it with CRC226 available at Home Depot in the electrical department. Sometimes you can restore controls damaged by WD40 or cleaners like Deoxit or Blue Shower.
Turn it upside down and spray with the tube near the center and at the ends to flush the WD40 out. Working the control back and forth. Finally, a squirt of CRC226 with the keyboard right side up and work the control. You have a better than 50% chance of fixing it this way.
Make sure you use CRC226 as there are OTHER CRC products at HD. Blue can about $2.70.
Faurite buttons bushed there is a quarter note gap
Not sure what you mean by "buttons". IF you are trying to change voices, a lag between sounding of the old and new voice can be expected as the generators within the synth are reconfigured for the new voice. This is a lower-end synth and as a result doesn't haved the performance of some of the newer ones.
If the lag is just between notes that are being keyed using the same voice, that is too much delay and something is probably set wrong.
I wish to know how
Usually there are a number of screws from the bottom to remove. SOmetimes they hide some under a label or rubber feet. The top should remove and pone must be careful of the cables from teh top to the base of the unit.
Keep track of where screws go as often they have different length and using the wrong length when re-assmbling caan cause trouble.
Hi. Can I use the second pedal on my Roland BK5 to scale up the key one semitone at a time?
Yes, you can use the second pedal on a Roland BK-5 keyboard to transpose the key of the music that you are playing up or down by a semitone at a time. To do this, you will need to press and hold the second pedal while playing the keyboard. You can also use the transpose function in the settings menu of the BK-5 to adjust the key of the music that you are playing by a specific number of semitones.
1/5/2023 4:04:49 PM •
Roland Music
Answered
on Jan 05, 2023
I need a circuit diagram for a Roland MA-15D speaker please?
It's a Chinese made Roland and no service information is available as when a fault is found the main board is replaced, eliminating the need for service information.
I would check that it is a stereo out jack and not mono. If it is a stereo out, check that both input phonos work. If they do, replace the faulty socket or damaged pcboard.
11/17/2022 6:14:26 PM •
Roland Music
Answered
on Nov 17, 2022
