20 Most Recent
Homelite Expand-It Hedge Trimmer Attachment Questions & Answers
Ryobi problems
Sorry not to have better news. The plastic housing on that trimmer is not strong enough to support the drive gears. Ryobi has discontinued that model.
I have had mine apart several times. The housing for the gear cogs is plastic and flexes. I've tried to reinforce it and added spacers between the plastic housing and the bearings that support the drive shafts in attempt to force the teeth together. But the trick only lasts for a few minutes. As soon as I start to cut with it, it stops again. It's just not worth the time, effort and frustration to continue working on it just to have it stop working again.
I finally discarded the Ryobi unit and purchased one with a metal (aluminum) housing. I think it is a Poulan Pro model from Walmart. It has worked well.
7/28/2014 6:16:43 PM •
Homelite...
Answered
on Jul 28, 2014
How do i start my
it sounds like your throttle cable is to long i have the same problem with mine... when starting up pull the throttle full on with your finger whilst you have it set on choke. best to do this on a very flat surface.
12/3/2010 1:23:48 PM •
Homelite...
Answered
on Dec 03, 2010
My hedge trimmer Mod# HT-19
Not for me to be a know all,but it is so important to clean and spray oil on these blades every time after use,but to new blades,who did you buy it from? the store EG Focus,Homebase,or others will all have a listed supplier,for spares repairs,but check out the price first,also check out the lowest price for a new one,rgds
9/25/2010 4:06:43 PM •
Homelite...
Answered
on Sep 25, 2010
Need sovereign hedge trimmer SHT 26 pull start
The agents for the Sovereign machine that you have aare Einhell.co.uk you can either phone them,(which I had cause to ) or mail them,but the spares are available as they order what you need,or do not have,rgds benji123
9/25/2010 3:57:06 PM •
Homelite...
Answered
on Sep 25, 2010
My edger attachment won't come
Not too sure of this model,have you tried to spray a "good" loosening fluid,where it is supposed to come off, TAP lightly!!! with a small hammer,LEAVE OVER NIGHT!! try to see if it releases,if not Repeat spray procedure,leave overnight and try again,if you don't have success,let me know,is this a petrol or electric model?? By the way did the machine get wet,when you then stored it away,if so the "good loosening spray" should loosen any rust/gunge that may have occoured,but let me know,rgds benji123
9/25/2010 3:53:18 PM •
Homelite...
Answered
on Sep 25, 2010
Has a hold in fuel tank
Hi Kenneth,
There is a solid epoxy sold at auto parts store specifically made to seal fuel tanks in vehicles. It starts as a solid (like clay), you knead it for a bit and plug the hole with it.
As it cures it expands slightly making a perfect seal.
Quick, easy and best of all: inexpensive.
Best regards,
Mike
8/17/2009 4:43:33 PM •
Homelite...
Answered
on Aug 17, 2009
