20 Most Recent John Deere 6300,6300l,6400,6400l Tractor Radiator Questions & Answers
JD 6400. My hydraulic is
Its a low transmission/hydraulic pressure.First, make sure your transmission fluid level is at the full mark. Also check if fluid is getting leaked from the lines.It's possible the fluid may be getting too hot. Check to make sure your radiator fins are not clogged. Pull the screen in front of the radiator and clean it, flush the radiator with water from the backside, you may need to pull some shields from the side of the engine to do this. Also as you mentioned that you hear a noise,it can be bad pressure sensor. It is located on the front of the transmission, above the transmission filter. If you have a pressure gauge, you can verify if it has good pressure.Also for buzzing sound, flush the hydralic system and fill it with fresh oil and if that dosnt work take the pump out and flush it manualy. Check the oil condition and relief valve.If the valve is getting stick the clean the valve and if oil is very dirty then replace the oil.But if oil is replaced just few months before and looks good then no oil change is required.----------- check out.this troubleshooting will point towards the faulty part.This should help.Keep updated.Thanks.Helpmech.
9/7/2022 8:23:04 AM • John Deere... • Answered on Sep 07, 2022
2answers
Ust changed the fuel pump on John Deere 6300 and will not start
Can you hear the pump run when you turn the switch on? If so, you have installed the pump correctly.
There could be an air lock...... there should be a handle somewhere for a manual pump you can loosen a fuel line connection and pump until the bubbles stop and all fuel comes out.
11/15/2018 8:36:07 PM • John Deere... • Answered on Nov 15, 2018
97 kia sportage making hissing noise and white smoke by driver windshield
Yikes, that sounds like an antifreeze leak. Most likely it is just a hose with a hole or crack. Lift the hood and try to see where it is coming from. One thing you must do is check the level of antifreeze or you could ruin the engine. If a red light comes on the dash, you will need to find a safe place to park and turn off the engine before it can overheat and be ruined. If you are not familiar with anything under the hood, you are best off taking it to an independent shop that has been recommended by another person.
12/2/2014 1:32:33 AM • John Deere... • Answered on Dec 02, 2014
0answers
Have to pull 600gator to start it
Push you stick to press it into nutrueal if that does not work wiglle back and forth on your seat while starting your tractor to move the wheels back and forth this may be a safty mechenisim desighned into your model
4/13/2014 10:04:24 PM • John Deere... • Answered on Apr 13, 2014
White smoke comeing out of breather pipe on engine of jd 6400
White smoke means water. Check your oil for water. You may a head gasket leaking.
3/16/2014 10:37:34 PM • John Deere... • Answered on Mar 16, 2014
0answers
0answers
0answers
John Deere 6300,6300l,6400,6400l Tractor Radiator Logo
176 questions posted
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
View Most Popular
John Deere Garden
  • John Deere Garden
Most Popular Question
white smoke comeing out breather pipe
  • Garden
