20 Most Recent
Hayden Industries SuperVac 3600 Central System Vacuum Questions & Answers
Hayden product. how to disassemble the head to
Actually Hayden's power nozzle is manufacturered by Panasonic for Hayden. Panasonic is the same maker of Kenmore vacuums as well. I have written a detailed repair solution on how to replace the belt on a Kenmore Canister vacuum, and the repair on your power nozzle will be identical.
Here's the link:
http://www.fixya.com/support/t4499227-need_replace_belt_in_kenmore_vacuum
The only difference could be that you may have a newer style power nozzle then this one, and the screws on the newer nozzles are actually on the bottom of the power nozzle rather then underneath of the headlights.
Hope this helped you,
Chris J.
GoVacuum
4/10/2010 2:52:29 PM •
Hayden...
Answered
on Apr 10, 2010
I have a residential hayden
Hi, the red light signifies that it needs regular maintenance on and the green light means it is full and dirty which needs to be cleaned and emptied.
Should in case you have done all this and this light (green/red) keeps coming up, then you have to reset it.
Concerning the noise related problem and for proper solution to all this problems associated with the vacuum cleaner, i will advice you to contact the factory phone number or website below to further assist you as per you questions.
http://www.haydenvac.com/company/company.html
Customer Service 1-800-461-5300
Company Phone # 1-705-726-3361
Company Fax 3 1-705-726-2186Take care
3/17/2010 12:14:17 AM •
Hayden...
Answered
on Mar 17, 2010
Hayden SuperVac central vacuum making an unbelievably loud noise.
Stop using the vac. Remove the filter and clean thoroughly, inspecting for damage. If the vac is spiting out bits off fuzz or lint it may need the motor cleaned and serviced as dirt has leaked past the filter. If it is spewing black, not gray this is carbon dust from the motor brushes. If the noise is scratchy or growling this is a sign of a motor problem as well.
The muffler unless it is a hepa filter/muffler combination is NOT designed to catch dust.
Exhaust dust is a sign of dust leaking through the motor which indicates future moor problems.
HINT, if the guy who installed the muffler didn't secure it right he is probably not a good choice as a service tech either. The muffler is normally clamped or secured in place with a small screw so it can be removed in the event of service.
9/7/2009 1:54:57 PM •
Hayden...
Answered
on Sep 07, 2009
Pc camera
Yahoo messenger is not very reliable.
It also may not be their fault it may be because when your camera was installed the computer at times can get confused with what type of hardware you have connected and it wouldnt put it as an option when selecting to install it on Yahoo.
I suggest you go onto a search engine and search this: Windows Live Messenger.
It works with any IM including Yahoo, AOL, Google etc.
I am sure it will properly detect your camera.
2/7/2009 1:19:16 AM •
Hayden...
Answered
on Feb 07, 2009
Hayden Supervac 3600
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11860&thid=808510
Posted by kdm0 on Jul 20, 2008
Hi, I have a Hayden Supervac 3600 central vac system in a house I just purchased. The Amber light indicating that it needs regular maintenance is on. I have cleaned and serviced the motor, everything is fine and suction is well. How do I reset the service light? The reset button seems to do nothing. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I heard of this happening before and you need to refer to the owner’s manual and or to contact the factory or manufacturer of which I will provide to you @ the end of this question. There may be some type of rely switch or board that might need replacing but check with the factory. If you need further help please refer to a local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
12/23/2008 7:11:12 PM •
Hayden...
Answered
on Dec 23, 2008
How to get into Hayden super pack delux vac unit
Are you speaking about the Power Nozzle? If so, you need to remove the head light cap. It has clips on each side. Using a small flat head screwdriver gently pry the light cover off from the sides.
Now you will see two screws. Remove those screws. Now you need to pull out on the sides of the cover while hinging it from back to front.
That is it. There is the motor, belt and electronics.
To reassemble, just revers the steps.
6/5/2014 3:20:00 PM •
Hayden...
Answered
on Jun 05, 2014
