20 Most Recent
AMD Athlon64 2800+, 1.8 GHz Athlon 64 (amdada2800axbox) Processor Questions & Answers
Download driver free
CPUs do not have drivers. They do not contain LAN, Audio, or Video components. These are part of the motherboard they are installed upon. You need to provide the
motherboard manufacturer, model number, and revision number, along with the specific Operating System you are running. We can then help you find the driver(s) you need.
Motherboard drivers
The issue of motherboard drivers is not affected so much by the processor itself as the chipset type/version installed on the motherboard and the operating system you plan to run on it. If you can provide the motherboard manufacturer, its model number and revision, and what operating system you are going to run, we can point you to the correct motherboard drivers.
I have amd athlon 64
A suitable graphics card will help your computer system display better graphics. You will need a graphics card and maybe you could do with at least 1GB of RAM.Take care!damnor01
I have a Asus P4GE-MX motherboard with processor
You will not find a better processor or replacement parts, this system is too old and parts are not being made. Newer systems are 4 generations better and prices are heading down, buy a new system with Intel CORE or CORE2 chips or the latest I3, I5 or I7 chip using DDR3 memory. DDR4 will be arriving in 2012, prices on old DDR3 will continue to go down.
Sir , i found my
Processors do not fail unless they are mishandled or installed incorrectly. This system is very old and uses memory that is no longer available. Try starting your system with no memory, does it start to beep repeatedly? The memory may be at fault. No beep, could be the motherboard has failed.You will not find replacement parts, you will need a new system.
Hi everyone I have AMD
Any motherboard, off-the-shelf, with a socket AM2 or AM2+ should work fine. None are being made, you will have to find old stock or used. New boards support AM3 and AM3+ using DDR3 memory now. The normat temperature range should stay below 60 degrees Celcius.
Cool & quiet: The motherboard bios controlls cooling. Turn it off and Windows can take over.
If you really want it, there is an extra software utility you can download from AMD to interact with the process, however it is not needed.
I have Installed Windows7 on
Test your PSU or replace it if your power supply units fan
is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including
electrical extensions,IDE,SATA
the leads from your
"((motherboard to your hard drive))" make sure they have a secure connection and
are not faulty or just replace them they could be faulty
make sure all leads that
are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections
and are not faulty even the electrical extensions or just replace them they could
be faulty a computer
needs its connections to continue its cycle and have an end so any faulty leads
will end up with a computer error hope this helps
I am repairing a computer for a friend. When I
depending on the number of beeps and their durations you can search your motherboards bios beep codes which should tell you the general area of the fail
try unplugging and re-seating
memory
cpu
videocard / monitor
these are the usual main culprits
Monitor not display when i turn on machine
Hello there,
Is the monitor gives you are red or green led light? Make sure the cables are connected to the computer. Try to turn on the computer with the monitor. Then get yourself a flashlight and look closely to the monitor screen and see if you can view the desktop or icons on it. If yes, then your monitor's backlight have failed and needs replacement.
Please let me know how this goes. Thank you for using FixYa
Amd athlon 2800+ drivers
Click here to download the drivers for your Processor.
Select Processor for option 1
Select AMD Athlon 64 bit family for option 2
Now click view results.
It will then show a list of the available drivers for your processor.
Select whichever is appropriate.
You would need the AMD Processor driver version 1.3.2.0053
damnor01
