20 Most Recent
Cook's Essentials CooksEssentials 3 Quart Stainless Steel Digital Pressure Cooker - - Questions & Answers
Pressure regulator knob broken
Do you think the knob is broken because it is loose? It should be loose and move easily over the valve. If it is really broken, you should contact the customer service of the home shopping channel where you purchased it.
2/21/2014 7:14:50 PM •
Cook's...
Answered
on Feb 21, 2014
Essential electric pressure cooker lid replacement
Cook's Essentials is a special brand produced for QVC. You should contact their customer service - their number should be in the instruction manual. If you don't have one, you should be able to find it here:
http://www.hippressurecooking.com/category/manuals/cooks-essentials/
12/10/2013 7:57:07 AM •
Cook's...
Answered
on Dec 10, 2013
I had macaroni stick in one of my pots, how do I get it clean. It's blk inside the pot,
To remove stuck on food use water (the world's strongest universal solvent). But add a degreaser. Degreasers change the surface tension of water molecules to make the water droplets much smaller. Once they are smaller they can get into areas to start dissolving what it could not approach previously. Detergent being a surfactant also allows mixing oils and water. Hot soapy water works better. We used to use boiling water in a chinese restaurant i used to work at. Boiling water helps alot. Since your food is charred it is more likely carbon sticking to the non-stick surface. Your non-stick surface must not be non-stick anymore due to using the wrong chemicals or pads on it. High temperatures make silicone type non-stick coatings fail too. If there is no more non-stick coating to worry about you could use an oven cleaner. Oven cleaners are made of caustic soda or lye. Lye is made from common table salt (sodium chloride) Oven cleaner is great at attacking carbon but not very friendly to aluminums or the finished paint on any metals on appliances. Use your own discretion.
10/18/2013 3:13:41 PM •
Cook's...
Answered
on Oct 18, 2013
How to replace bottom in steamer basket on Cook's Essentials 3 tear steamer model 97500 steamer
To replace the bottom in the steamer basket on a Cook's Essentials 3-tier steamer model 97500, you can follow these steps:
- Disassemble the steamer by removing the lid and the baskets from the base.
- Locate the bottom of the steamer basket that needs to be replaced. It may be attached to the basket with clips or other fasteners.
- Use a flat-headed screwdriver or another tool to gently pry the bottom of the steamer basket away from the rest of the basket. Be careful not to damage the basket or the bottom as you do this.
- Once the bottom of the steamer basket is free, remove it from the basket and set it aside.
- Take the new bottom for the steamer basket and carefully fit it into place in the basket. Make sure that it is properly aligned and securely attached to the basket.
- Once the new bottom is in place, reassemble the steamer by placing the baskets back into the base and attaching the lid.
- Test the steamer to make sure that the new bottom is functioning properly and that the steamer is working correctly.
If you encounter any difficulty during this process, it is recommended that you consult the instruction manual for your Cook's Essentials steamer or contact the manufacturer for assistance.
12/15/2022 11:23:01 AM •
Cook's...
Answered
on Dec 15, 2022
Can I used boxed bread maker items in my cooks essentials 850
Yes you can, but you are also buying all the preservatives as well. Bread has so few ingredients it really isn't worth it.
Bread Flour
Water
Yeast
A little sugar to feed the yeast
Oil
Salt
A Pro tip, weigh all your ingredients, rather than using Cups and Spoons as volumetric measures. Follow John Kirkwood on YouTube. I made Sourdough yesterday, a Rustic Farmhouse loaf of his last week.
2/7/2022 7:07:36 PM •
Cook's...
Answered
on Feb 07, 2022
I need a manual for a Cook's Essentials Roaster Oven 420TS
Manualib.com has all the manuals that you can find and as long as your online 100% free. Just have your make and/or model number ready... you can find any manual even the ones that are hard to find. It also gives you the option to download, print, or even buy a copy of what ever your looking for... Hope this helped.
7/18/2019 6:50:39 PM •
Cook's...
Answered
on Jul 18, 2019
Where can I geta replacement seal for cook's essentials 2 qt pressure cooker
Hello, Kathy -
If you use the Edit feature and add the model number of your Cook's Essentials pressure cooker, I may be able to determine what company manufactured the pressure cooker for QVC. It seems QVC is the only seller of products with the Cook's Essentials brand name.
With that being said, if you have the user's manual for your pressure cooker, near the end of the manual may be a section on service and repair. If so, there may be a phone number listed there you can call to find out about purchasing a replacement seal (the gasket) for your model.
Or, you may wish to telephone QVC Customer Service and ask where to purchase a replacement gasket for your model pressure cooker:
888-345-5788
7am - 1am Eastern Time, 7 days a week
12/31/2017 6:37:10 PM •
Cook's...
Answered
on Dec 31, 2017
