20 Most Recent Napoleon Patioflame "Campfire Style" Log & Burner Set - Natural Gas Questions & Answers
2answers
Do I need to hire someone with a lisence to
unless you feel excedingly confident with your skills i would hire someone regaurdless, someone with a license is also trained to hanle the materials that deliver the gas.
2/4/2010 11:40:26 PM • Napoleon... • Answered on Feb 04, 2010
Remote does not work
turn everything off then turn back on some of these are like a computer reboot while system
5/8/2014 1:00:28 AM • Napoleon Pool &... • Answered on May 08, 2014
Napoleon gas fireplace troubleshooting
??? - and the problem you need help with?
1/29/2014 7:19:54 AM • Napoleon Pool &... • Answered on Jan 29, 2014
Even if I turn the non digital thermostat to off, it will not go off.
I hope you cut the gas off at the meter. This is called a runaway heater, and should not be used! The gas valve probably stuck open or someone has rigged it. Get a tech to check it out.
1/17/2014 4:53:27 AM • Napoleon Pool &... • Answered on Jan 17, 2014
0answers
Stove regulator
What kind of regulator?
10/24/2013 11:41:26 PM • Napoleon Pool &... • Answered on Oct 24, 2013
0answers
I have a quadra-fire 1100-i and I can not get power to the ignitor
Be careful how you read the voltage on the ignitor, as it has a low resistance and may not show a voltage across it. As is the case with most parts, you can use a line cord to hot wire the device to test it. Remember, the stove has a 10 minute exhaust fan timer when its first plugged in, so the ignitor will not light until this has timed out.
3/6/2013 12:04:28 AM • Napoleon Pool &... • Answered on Mar 06, 2013
2answers
LifeSmart LS350 Plus Hot Tub Jet Spa. Can I convert my LifeSmart LS350 Plus 110v to a 230V
Question edited for clarity. Question moved from Computers category. Yes if you swap everything that is connected to electricity over to 220 volts. It is marketed as a 110 volt spa eliminating the problems of running 220 volt power. https://www.google.com/search?q=lifesmart+ls350+plus+220+volt ..
4/14/2024 9:55:26 AM • Pool & Spa • Answered 2 days ago
2answers
How do you clear a general fault on the power supply of Minimax NT5000 24V/15A-HR?
Contact the manufacturer 1 800 863 3930 for specific information about this. The manual does not include information for getting rid of a general fault. https://www.alpha.com/download/outside_plant_power/cableups_power_supplies/broadband_ferro/install_oper_manual.pdf
3/17/2024 4:14:55 AM • Pool & Spa • Answered on Mar 17, 2024
2answers
My Maax 461 Spa Heater heats constant until overheat and trips out until manually reset. If jets not turned on, the heater will overheat and trip. Acts like contacts stuck?
Question edited for clarity, 'till' refers to turning over soil, 'tilling', 'until' is the word you need. That sounds like a thermostat problem. The heater should only be on when water is circulating, even if it is just in the standby mode before the high pressure jets are turned on. Contact your installer or one of the parts suppliers in the link. It is unlikely to need a new mainboard. https://www.google.com/search?q=Maax+461+Heater ..
3/17/2024 4:08:41 AM • Pool & Spa • Answered on Mar 17, 2024
2answers
What is chemistry?
Chemistry is the branch of science concerned with the substances of which matter is composed, the investigation of their properties and reactions, and the use of such reactions to form new substances.
3/17/2024 4:06:29 AM • Pool & Spa • Answered on Mar 17, 2024
Napoleon Patioflame "Campfire Style" Log & Burner Set - Natural Gas Logo
1 questions posted
Top Napoleon Pool & Spa Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Napoleon Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Napoleon Pool & Spa
  • Napoleon Pool & Spa
Most Popular Question
need hire someone lisence
  • Pool & Spa
