20 Most Recent Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas / Max E Glas Questions & Answers
What bearings do I need for a sta-rite JWPAS5F-2A4
there is a possibility it might use the most common 6203 2rs or 6203 2rs 5/8 bore, these are a hard motor to work on, you must be careful pulling the front bearing as it is easy to bend the threaded portion of the shaft, and breaking or bending/breaking the start switch is always a possibility, and these parts are near impossible to find ! I wish you the best of luck... jay
1/2/2015 9:12:53 PM • Sta Rite... • Answered on Jan 02, 2015
Need bearing within PN C103-137P1 , higher
most of these are 6203 2rs c3 bearings used in this motor. here is a picture on how to remove your pump for service, i would suggest professional repair to avoid extra costs.. just search your area for yoour local pool pump motor repair guy..remember to prime the pump after any pump repair ..jay 11_2_2011_5_05_43_pm.gif
11/2/2011 5:06:02 PM • Sta Rite... • Answered on Nov 02, 2011
The motor is running OK, but it won't pump the
a suction leak will cause the pump not to prime... check the lid gasket, lid for cracks,pipes and valves. you can rap the fittings with electrical tape, to help you locate leaks.. a shaft seal is a good start, this will allow you to ree the condition of the impeller . it may be plugged, also see if there is cracks in the hair basket it will allow trash to get into the impeller
11/2/2011 4:59:52 PM • Sta Rite... • Answered on Nov 02, 2011
2answers
Removing a staRite pump
a picture on how 2 remove sta rite , remember to prime the pump after any repair !.. the shaft seal used on this pump is a 100 or a 200 . i use pac seal mechanical shaft seals cost about 10$.. go kits are not required on 90 % of repairs $$11_2_2011_4_50_15_pm.gif
11/2/2011 4:53:59 PM • Sta Rite... • Answered on Nov 02, 2011
We have a Sta Rite SR400NR when we turn it on we an error code 180 then c 8 then it shuts off
Check the control wire that might be connected to the control fuse. If that wire is open the unit will only cycle thru the board information and the sit dormant until the control is called for.
5/1/2020 6:06:40 AM • Sta Rite Pool &... • Answered on May 01, 2020
0answers
0answers
WATER WELL WILL NOT PRIME OR PUMP WATER
replace the mechanical shaft seal. check impeller and diffuser for damage . prime pump after any repair
12/2/2017 7:36:46 AM • Sta Rite Pool &... • Answered on Dec 02, 2017
Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas / Max E Glas Logo
8 questions posted
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Sean Wright
Sean Wright
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Sta Rite Pool & Spa
  • Sta Rite Pool & Spa
Most Popular Question
bearings need sta rite jwpas5f 2a4
  • Pool & Spa
