Thank you for posting your question here on Fixya.com.
The pump seal and/or volute gasket in the pump have failed and need to be replaced.
In general the process is the same for any brand...Disassemble the motor from the pump, lock the motor shaft at the end opposite the pump, spin off the impeller (which may be covered by what is called a diffuser), replace both halves of the seal (one is pressed into the pump housing and the other rides against or on the back of the impeller) and assemble in reverse order.
While it is apart, check the oring recessed in the cover or body for nicks or compression damage. Replace it if you find any. The seal is usually a #200 in Aquaflo pumps. Part should be under $15 and available from a local pool/spa store or a pump repair shop in your area. You may want to take the old parts with you to ensure proper replacements.
If you need more specific directions, please add a comment with your question(s) or contact me using our web site at www.arrowpools.net.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
3 questions posted
