20 Most Recent Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Questions & Answers
3answers
The foam instulation in my hot tub cover broke from heavy water
Pretty hard to repair. If the outer shell is intact, just use it. You may open the cover and take the foam out, duct tape it and reinstall. Other than that, you have to buy a new one. Good luck...Lee
1/25/2020 2:16:49 PM • Qca Spas Dream... • Answered on Jan 25, 2020
2answers
I am getting a Pr code and the tub is not coming on at all
follow this steps and fix it. God bless you If the unit won't start, make sure power is on at the electrical outletor the electrical panel Then test the pump and the motor. Check for and repair broken wires or loose or corroded terminals. If necessary, have the pump switch control tested and serviced professionally. If the jets do not work, clear a blocked water intake of hair and other particles (see below) or replace a broken jet (see below). If the water in your spa or hot tub is too hot or too cold, check to see if the high-limit reset switch has been tripped and, if needed, reset it. Adjust the thermostat setting and have the thermostat serviced if the problem persists. If necessary, test and replace a faulty heating elements 125a10b3-4403-4cc7-8741-9137c999473e.jpg
3/24/2018 5:08:01 AM • Qca Spas Dream... • Answered on Mar 24, 2018
0answers
0answers
0answers
0answers
Where can i view a leisure bayhot tub manual?
You can find a copy of the Leisure Bay hot tub owners manual on The Cover Guy website. We also have a guide for error codes and information relating to Leisure Bay hot tubs. Leisure Bay Spas Hot Tubs Information
2/3/2016 8:43:00 PM • Qca Spas Dream... • Answered on Feb 03, 2016
3answers
What does FL mean on my hot tub??
FL could be a code for low flow. If you have no circulation this sounds like it. If your pump runs and you have no flow you could have a problem with your pump. Or if you have the tub drained then it could be an air lock, if you open the drain valve till you get water out that should fix that. Also check to be sure the isolation valves are open under the spa. I hope this helps.
2/3/2016 8:37:41 PM • Qca Spas Dream... • Answered on Feb 03, 2016
Why does the spa trip the gfci when I turn the jets on high?
You need to make sure that it is a real GFCI and not a spark detection fault interrupter. When the pump is turned all the way up it may be causing a large spark that the SGCFI is detecting. If it is not that then there is a parasitic floating fault that is causing the issue.
5/3/2015 1:54:11 AM • Qca Spas Dream... • Answered on May 03, 2015
I have this pump modelpf-40-2n22c cam i chang it out for this model numbert55cxcas-1179
If the water flow according to each pumps spec's match up and the plumbing lines up, with little or no modification, then all is good. but... remember this, if the water flow does (GPM's) not matchup, you will ever overdrive your hydraulics system causing premature leaking, or if undersized, your jet action will be diminished! you can find this information by obtaining the "Pump Curve" chart from each pump manufacturer. btw... The numbers you provided don't help much. Make and model name of each pump??
4/2/2015 3:55:59 PM • Qca Spas Dream... • Answered on Apr 02, 2015
Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Logo
106 questions posted
Top Qca Spas Pool & Spa Experts
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Qca Spas Pool & Spa
  • Qca Spas Pool & Spa
Most Popular Question
spa trip gfci when turn jets high
  • Pool & Spa
