20 Most Recent
Golden Technologies Golden Alante Jr Questions & Answers
Need wiring diagram for Golden
Monterscooterpart.com if not on there site give them the sr# and they get you your diagram. Your welcome..
1/24/2011 3:33:35 AM •
Golden...
Answered
on Jan 24, 2011
Why doesn't my golden technologies scooter turn on or move
You will have to do a complete system check and know how to use a multimeter. I recommend contacting a Certified Technician but if you wouls like to try; Start at the batteries. Check each battery voltage. If the battery reads lower than 12.4 V, charge batteries overnight prior to continuing. After charging the batteries should read at least 12.6-13.0 V. If not, take batteries to a supplier for a load test, chances are the batteries need changed. Assuming they do not, at each connection, check the voltage from the batteries to the control module/front to rear harness/ control panel. If you have proper voltage at all points, then check your resistance from solenoid brake/motor. You should be able to find the problem.
9/21/2015 9:45:22 PM •
Golden...
Answered
on Sep 21, 2015
