20 Most Recent
Shoprider Sunrunner 4 - 4 Wheel Scooter Questions & Answers
Howtoremoveseat?
W beck you have to remove the seat by pulling it out of of the seat post and then remove the shroud or cover by pulling it straight up You will then be able to see the
batteries. Your scooter equires two 12 volt batteries probably U1 batteries Hope this
helps
10/13/2015 12:26:23 AM •
Shoprider...
Answered
on Oct 13, 2015
Hi there i have a sHOPRIDER MOBILITY SCOOTER WHICH
The battery it is dying and it dead and the core of the battery it self can't retain enough the of charge of the electricities for to the battery to move the scooter.Change to a brand new battery ur scooter should work fine.
3/8/2014 1:52:48 AM •
Shoprider...
Answered
on Mar 08, 2014
How to change tires
The centre comes in 2 parts,using a socket set.Use a valve tool to allow all the air out of the inner tube unless,the wheels are solid tyres.
3/4/2014 1:06:41 AM •
Shoprider...
Answered
on Mar 04, 2014
How do i find the vin nuimber
Slowly find, <a href="http://www.solartech.cn/">believe in yourself</a>, always know.Please sign in:http://www.solartech.cn/
7/25/2012 8:21:01 AM •
Shoprider...
Answered
on Jul 25, 2012
Trip breaker,reset it but no power to anything
Probably just a fuse somewhere. Does your battery meter work? If not, there may be a fuse on the battery harness thats blown. Failing that, depending on what make of control box is fitted to your scooter, it could be a fuse within this that has blown.
11/18/2011 9:08:23 PM •
Shoprider...
Answered
on Nov 18, 2011
How do you get at
Remove the seat by pushing on the seat release handle and pull it up off the seat post then remove the rear shroud cover and there are the batteries undo the velco strap and remove the wires from the battery post and replace with the fresh batteries Hope this helps
6/12/2011 10:36:32 AM •
Shoprider...
Answered
on Jun 12, 2011
I HAVE GOT SIDE TO SIDE PLAY ON MY SHOPRIDER
ok, under the front steering rod, you will see a screw type ball bearing holder,
First lubricate and then tighten it using your hand , then a plumbers wrench etc, but not too tight otherwise the steering may get stiff.
Regards
GeWiz
10/11/2009 1:46:41 PM •
Shoprider...
Answered
on Oct 11, 2009
