20 Most Recent
NRS Resperate Blood Pressure Lowering Device Questions & Answers
Can a 33amp hour battery be used in a mpv5hoveround
If it is a 12 volt Size U1 - yes. (UB12350, GPC1234, GPL-U1, NP33-12B)
The amp hour rating is dependent on use and manufacturer of the battery. It is the size and voltage that matters. AGM batteries generally have a slightly lower AH rating but recover better from deep deep discharging cycles. (Available at marine stores)
The amp-hour rating affects how long the chair will travel between chargings.
Hoveround technique rwd motorized chair charge
Normally the power chairs will not operate when connected to the charger. If you mean the controller comes on when connected to the charger but it wont come on when the charger is disconnected, I would test the batteries first, then the connections and fuses. Did a technician inspect your power chair to determine a controller was needed, or was that just a guess by the representative over the phone? If your insurance will not cover the repairs, I would recommend spending $50 for a technician from Hoveround to come out and inspect the chair to determine what is needed to fix it so you know for SURE. It may be something simple and inexpensive.
How many protein bars should I eat per day?
Go with whole food proteins or quality whey shake. Make sure you know what you are eating, Cliff is probably one of the highest rated ones, so two bars would be fine along with normal meals. Whey protein is a naturally complete protein, meaning that it contains all of the essential amino acids required in the daily diet.
Whey protein is a rich source of branched chain amino acids (BCAAs), containing the highest known levels of any natural food source. BCAAs are important for athletes since unlike the other essential amino acids, they are metabolized directly into muscle tissue and are the first ones used during periods of exercise and resistance training.
Whey protein provides the body with BCAAs to replenish depleted levels and start repairing and rebuilding lean muscle tissue.
How often should I visit my dentist?
Most adult and children visit the dentist for regular
checkups and cleanings every six months. People at greater risk should have
checkups more often.
Charger not working plug in light stays green, but battery is not charged
I have got 3 different chargers for my scooter. It's a Tifgalop T108. The charger light would stay green on the new chargers. My old one was the only one that was charging it. While I was replacing the charging ports, I came to find out that the negative wire is in a different location on the new ports. The negative wire was on number 3 on the old ones and is in number 2 on the new ones. After changing the ports all my new chargers work fine now.
